Question about Whirlpool Duet GHW9150P Front Load Washer
Controlled lock light is lit and washer won't turn on?
    President:
  • 949 Answers
Here is a link to some instructions for unlocking the duet.
http://www.fixya.com/support/r4624473-control_locked
Posted on May 10, 2010
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
    see this causes and fix it. God bless you
    Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse If the washer won't start the line fuse might have blown.
    Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
    Controls locked
    The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
    Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
    GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
    GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
    Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
    The "Control Locked" light is
    Mar 31, 2011 | Washing Machines
    Control is locked
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the
    Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet washer
    PRESS AND HOLD CONTROLS LOCK/UNLOCK (END OF CYCLE SIGNAL)FOR 3 SECONDS.
    Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    171 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
