Question about Hitachi Televison & Video
CAN I CLEAN THE MIRROR ON MY HTACHI 43FDXOIB TV
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
With the set unplugged remove the back cover of the set.
Next remove all the screws on the entire large plastic shroud that is black in color; you will notice hand holds to lift it free and the mirror is attached to the inner side.
l usually use paper towels and glass cleaner to clean it and also clean the three large black plastic lens in front of it. It either is dirty or grimy the picture will be affected.
Carefully replace the mirror/shroud unit and put all the screws back that secure it.
Replace the back cover and see what it looks like. There is no access from the front of the set to do this.
SD TECH
Posted on May 09, 2010
Hitachi projection tv mirror problems
the mirror in projection tv, needs to be cleaned along with the lenses for each crt clean them both and your tv will look like new good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
I have a hitachi 55vf820 lcd rear projection tv. How do you get the cover off to clean mirror?
Don't try that as the mirror almost never needs cleaning and MUST be cleaned with a special cleaner---leave a single fingerprint on that mirror (or a smudge) and it will stand out in the picture like a sore thumb.
Reason to clean mirror?
Apr 09, 2012 | Televison & Video
My Sony KP53S35 rear projection TV has a very dim picture and I was told that I need to clean the mirrors. Can you tell me how to take apart the TV to get to the mirrors and how to clean them?
chance are your problem is the projector lamp and not the mirrors. if the tv is 4 years old or more buy a new lamp, they are easy to change. as far as the mirrors go, you have take the back off to get at the mirror but its a lot of work try the lamp first.
Mar 12, 2011 | Televison & Video
Can you clean the large mirror inside a DLP tv? If so with what?
Hello.. i will gladly help you..
first of all what is your tv model i need to now because there different typre os mirrors. and its really simple to clean the problem is figuring out were is it depending again on the brand..
if you send me the info i can show you how!
and you can clean it like you clean any mirror in this case extra carefully!
Dec 29, 2009 | Samsung HL-S5087W DLP TV
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
How do i clean the mirrors on a big screen tv
In most cases you can remove the back of the TV and get up inside the cabinet to clean the mirror. Windex works great on any glass mirror, but if it is mylar, a less harsh cleaner is better. If you have a newer digital type projection, you will likely have to go in through the screen to get to the mirror and it is much more difficult. I can instruct more depending on type and model of tv.
Dec 06, 2008 | JVC Televison & Video
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Mirror
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Nov 12, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
222 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
