Question about GE 24 in. GSD4020Z Built-in Dishwasher
My Quiet Power II / GSD4020Z00BB does not drain completely
My Quiet Power II / GSD4020Z00BB is about 7 years old and just started to incompletely drain after a cycle leaving about 2 inches of water in the dishwasher. The drains and the connections to the food disposal are clear. I intend to follow the guidance offered in the solution you provided above and replace part WD24X220, but before I order a part can you tell me if the GSD4020Z02B mentioned above is the same as machine as my GSD4020Z00BB??
catriver
  • 878 Answers
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Posted on Jan 27, 2007
  • 641 Answers
SOURCE: Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
micromaster
  • 3614 Answers
SOURCE: dishwashing machine not fully draining (2 inches of water remain)
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Posted on Apr 22, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
jtbjtb
  • 135 Answers
SOURCE: Water not draining whirlpool quiet partner ii
Remove the drain line where it hooks into the disposal. See if the plug, which must be removed to let water thru, is still in there. I ran into this on a service call a few years back. Removed to plug and voila! Hope this helps!
Posted on Jan 13, 2009
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Jenn air quiet series ii
had a similar problem i just replaced the drain pump and it worked.
Aug 17, 2013 | Dishwashers
Replaced the control board of my quiet partner
clean light flashing is a power interuption between the heater and the control often its is actually the door switches from not closing the door evenly but a chance that the heater is bad.also if you replace the main ccu it should have a software update that buypasses the fault and a good start wouldd be to reverse the door switch and test your heater for ohm values you want it to ohm out
Jun 02, 2010 | Dishwashers
My whirlpool quiet porter II dishwasher doesnt drain completely
not much info to go on but here goes...usually that problem is because the drain line into sink or whereever is too low. must go up from D/W soonest and go as high as possible.then into drain system.prevents drain back into D/W.also drain can be plugged up.. (hose) good luck ...paul
May 21, 2010 | Whirlpool Dishwashers
Kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Oct 25, 2009 | Kenmore Dishwashers
Quiet Series 200: The water is not draining out.
6 to 7 years is about right without put out major repair costs. Unfortunately salesmanship is the biggest racket going. I'd scrap it or sell it for parts. Sorry
Jun 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE 24 in. GSD4020Z Built-in Dishwasher Logo
133 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
