Question about Char-Broil QuickSet Traditional 463733003 (LP) Grill
Want to move from gas to charcoal - Char-Broil QuickSet Traditional 463733003 (LP) Grill
  • 8,220 Answers
If you do that you will ruin the gas components.
Posted on May 09, 2010
2000 hyundai elantra evap charcoal canister problems repaired
replace charcoal canister and prob canister close valve as well to be safe.
Dec 19, 2012 | 2000 Hyundai Elantra
Service engine soon light came on, replaced gas cap it went off but a week later it came back on, when it try to fuel the truck it spill the gas back out like it is a full tank
One of the most common causes, is blockage in the venting system from fuel entering the vent lines and into the charcoal canister, the fuel gets absorbed by the charcoal canister causing it to swell and block vent lines. the gas tank contains both fuel and air. when you fill it up the gas displaces the air and the air has to go somewhere. but the air that is displaced is full of gas vapor so the gas vapor goes to the vent lines and into the charcoal canister, when the charcoal canister swells up it prevents the air from escaping the tank, canister could be clogged,canister filter may need replacement,electrical connection to the close valve may be open,canisterf might be damaged,purge valve from canister might be clogged,vent hoses might be clogged, the vent hose could be clogged, or the vent hose may have a kink. all this is caused by overfilling the gas tank, getting that last drop of gas in the neck of the fill tube.
good luck!
Aug 11, 2011 | 2005 Nissan Titan
Gas pump keeps tripping off often
you have a bad charcoal canister. Go underneath the left rear of the car, pull the big hose off the charcoal canister, and if charcoal come out of the hose, replace the canister. This is a common problem w/Hyundai and Kia.
Oct 14, 2010 | Hyundai Sonata Cars & Trucks
When I go to the gas station it takes more than 10 minutes to fill the tank. The gas won't go in. I have to keep pulling the nozzle out to let air out and then some gas comes out too. What a mess. How do I...
The problem is the Gas tank charcoal filter.The charcoal tank is located under the spare tire wheel well. Connected to that is 2 lines that go to each of the rear tire wells, tucked up on the drivers side is a pump/filter and on the other side there is some parts that are then connected to the tank. If any of these parts are not letting air out of the tank the tank then gets pressurized too much causing the pump to shut off. If you want to see if this is the problem just pull the cover under the car just below the trunk, pull off any of the 3 pipes going to the charcoal tank that is under there. Dont worry none of the fuel will come out, just air moves thru these parts.
If you need further assistance please let me know and i will be glad to assist you from there. Thanks, MIdwest-tek
Aug 31, 2010 | 2000 Audi A4
Which smoker is better - gas, electric or charcoal?
The electric smoker is made to be the most convenient and easiest to use smoker.However, the electric smoker has limited adjustability in regards to cooking temperature. The gas smoker is convenient and portable, but a gas tank is required for use. The gas smoker offers a greater range in cooking temperatures. The charcoal smoker has an adjustable temperature range and charcoal chips or nuggets are required to operate.
Aug 12, 2010 | Crosley Grilling
Aug 12, 2010 | Grilling
I overfilled my Jeep Grand Cherokee on my first fill up and now I smell gas every time I fill up. I now stop at the click. I am told it is probably my charcoal filter because I keep smelling gas and the...
The charcoal filter is used to filter fumes from the fuel tank. There is a vent line, that comes from your fuel tank to this filter. (Charcoal canister)
Now since the charcoal filter has been completely soaked with gasoline, it will no longer function as it should. Even with vapors from the fuel tank vent line, the canister only has a working 'life' of so far.
You will smell gasoline in strong amounts until it is replaced.
Can't comment whether it is safe or not. (In my thinking, you are driving around with a charcoal canister, that has a charcoal filter soaked with gasoline. I wouldn't use it this way, but that is just my thoughts)
Sep 12, 2009 | Jeep Grand Cherokee Cars & Trucks
Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
Error code p0446 for 2001 cevrolet malibo
There is a pressure loose in your EVAP system, the best ting to do and the cheapest is to replace the gas cap. Don't buy a cheap gas cap, go buy a dealer gas cap for your car and hope that will address the issue, if the code is still there. Then move to the next common problem and that would be the vent on the charcoal canister could be dirty and clogged or there may be a solenoid vent valve failure. These are just a few common things to look for. Recap: change the gas cap, check the vacuum tubes to the charcoal canister and vent to see if there is dirt in the vacuum line. Good luck and hope this helps. Keep me posted, be glad to help
Jun 15, 2009 | 2001 Chevrolet Malibu
Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Jul 20, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Char-Broil QuickSet Traditional 463733003 (LP) Grill Logo
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
