Question about Kenmore 54501 Dehumidifier
Duhumidifier will not work
When I turn it on it registers as 01% and says bucket full even though it isn't. I can move the humidity control up.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 10, 2010
Bucket full light flashes, humidity setting won't change - only says 01
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
The bucket full light flashes even though its empty and inserted correctly and the humidity level is stuck at 1%. The unit as a whole just seemed to stop working.
I have the exact same problem. I suspect this is the same as the "CH 01" problem others had with a different unit that seemed to be the bucket switch. I still need to confirm.
Nov 21, 2010 | LG LHD65EBL Dehumidifier
Bucket full light flashing but not full, humidity % shows as 01%
I posted an extended answer to this problem with part replacement info and pictorial. Why hasn't this solution been posted???
venasguy@comcast .net
Jan 28, 2010 | Kenmore 54501 Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Jan 09, 2007 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
267 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
