Question about Xerox Office Equipment & Supplies
We have a xerox 3030 machine that throws toner where the paper exits the machine. What causes this to happen? It as uses excess toner and we have dark streak on the left side of the paper. We need to do a cleaning of this machine. Could you tell us why this doing this and how to clean the toner from the machine.
    New Friend:
  • 44 Answers
The most possible cause for this is that the waste toner bottle if full causing the waste tonert to drop of the drum module.The waste bottle is located to the right side of the machine.If you open the right side door you can see it.It is a black narrow/long bottle.Replace it or empty it.It might take some time before it clears out.Still it is best if a technitian removes the drum module to clean it.I would not recoment the removal of the drum from a non trained person, for this is quite hard to do
Posted on May 14, 2010
Hp laserjet 3030 paper jam
I would start here by cleaning the feed rollers but there could be several causes to this. It could be the fuser film is slipping and not getting the paper out in time thus throwing a false paper jam message. It could be the fuser isn't turning at all and not allowing the paper to enter. Normally if the paper is making it out of the tray then it isn't the feed roller but that is always the cheapest place to start. You can clean the roller(s) with an alcohol wipe or rag with alcohol on it.
Does the paper make it past the toner cartridge? I have seen toner cartridges lock up and cause this type of problem as well. If the paper isn't making it past the toner I would try replacing the cartridge (even if its with an old one just to test the paper path).
Feb 19, 2015 | HP LaserJet 3030 All-In-One Printer
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
I have a xerox machine for ricoh mp 1600 le. now i have a error of 542. so please tel me what is the problem of xerox machin?
SC542 code on Ricoh's means that the fuser unit is not heating up properly. The fusing unit is the part that "fuses" or fixes the toner onto the paper and is located right where the paper exits your machine. Most of the time the SC542 code means that the thermister(s) in the fusing unit have failed. The thermister measures the temperature in the fusing unit. When these go bad the machine can not "see" the unit heating up so it throws the code. The thermisters will need to be replaced and the code cleared out from the machines memory by gong into the service mode. I would recommend calling your local service provider to effect repairs.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Office Equipment & Supplies
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
We have the Xerox WorkCentre 665 and it's printing so light.
You can pull the developer houseing out. Wipe the mag roll, so it has a shinny area.
in a small area. Enter the developer housing in again.
Try running a copy.
Remove the developer housing and see if the mag roll moved. If it did not and it is still shinny and clean, this is the problem with light copies. Possibley bad developer housing or ciruit boards. Both are costly.
One other area is, if the developer housing is working, see what brand of toner you are using on this machine?
If it is a brand other than Xerox, dump it all out.
The developer housing has to be completely emptied.
Enter the Xerox toner and see how it works.
Also, a bad Transfer corotron can cause this problem, it may be arching in the blocks.
If all else fails, call Xerox for this major repair.
Feb 23, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
Tonor along edge of paper on my Xerox WorkCentre XL2140df
I would think you just have another bad cartridge. have you simply tried shaking it side to side? May just be built up on one side, but those cartridges are notorious for going bad. You need to vacuum the machine out well also. That toner and developer get in all those little plastic supports and can cause toner to dump.I would say the chance of a bad cartridge again is about 95 percent.
The printing problem. Have you tried downloading the driver from the Xerox.com site? Or simply reloading the driver. Sounds like its corrupted somehow. And when you change the tray, you are clicking apply?
Dec 17, 2008 | Xerox WorkCentre XL2140df Laser Printer
Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Mar 07, 2008 | Xerox Phaser 7400DN Laser Printer
222 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
