Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Poulan Twist N Edge TE 450 CXL Need to know how to remove spool to replace string
5 Suggested Answers
  • 15 Answers
SOURCE: I replaced both broked fuel lines and it still doesn't start.
Make sure the line is connected to the fuel cap if it has a pump ball.
Posted on Apr 24, 2009
SOURCE: poulan te 450 cxl fuel lines need routed correctly
Other line is just left open like to send gas back from the carb.
Posted on Jul 15, 2009
#1 Taper
  • 1040 Answers
SOURCE: how do you replace the
See if my Tip help you out. Just click on the link:
www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
Good Luck!
Jim
Posted on Aug 12, 2011
2strokeJim
  • 577 Answers
SOURCE: How to replace flexible drive shaft on Poulan
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Posted on Aug 30, 2011
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Aug 29, 2011 | Poulan Garden
Poulan Twist N Edge TE 450 CXL - has ran great for 10 years. It still runs great and fires right up every time - except now it will run for about 8-10 minutes, then it will just abruptly die. It then...
Hello, W/D here.
Check the pinhole vent in the fuel filler cap. As fuel is removed when the engine is running, air is pulled into the tank. If the vent is blocked, a vacuum is formed, and fuel cannot flow. After a period of down time, air infiltrates back into the tank, and the engine can be re-started. You can test this out just by cracking the cap open after starting the engine, just enough to allow air to get into the tank.
Best regards, --W/D--
May 02, 2011 | Poulan 17" T&E Gas Trimmer
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Jul 16, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Cannot get spool out of Poulin Weedeater Lite
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 27, 2009 | Poulan Garden
Apr 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need instructions on how to put line in Poulan Twist N Edge TE 450 CXL weed eater.
Dear FixYa Fan, Friday 2-20-2009 10:37pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear jebkillion: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
766 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
