Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Can't connect to Belkin N1 Wireless Router
I just had to reset my Belkin N1 wireless router to factory defaults. My roommate has the WG111 and is now unable to connect to the wireless network. Any suggestions?
  • sogrot Apr 23, 2008
    I cannot connect to the internet via my Orange (Seimans) router. Orange "experts"...four of them so far, have failed to slove the problem.
    At one point I had the Netgear WG111 v3 up and running with"excellent" signal strength, but I was advised by Orange to change channel from 11 to 13...sinc signal and no connection...and I don't know how to change the channel back to 11!!
    Can the router they sent me be the problem. Help!
    Stuart. UK
  • 4 Answers
Apply the basic sequence, after ressetting the router to factory default, plug it off, shutdown your pc, plug in back the router and turn your pc ON and then Start configuring your router.
1. SSID should match each other
2. Security type should be the same
3. If connected, but can not transfer data, adjust your RTS Threshold.
Noel A. D.
Posted on May 23, 2008
  • 61 Answers
When you reset the router to factory defaults everything goes back. so try to connect with cat5 cable and in IE link bar type and you will get the set screen of the router admin and password sholud get you in the you can look at the settings wep, etc. then change you pc to match
Posted on Apr 24, 2008
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address ( is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL.
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Dec 09, 2012 | Belkin Computers & Internet
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
Need to reset Belkin N wireless router
well, to reset the router press and hold the reset button on the back of the box for 10-15 seconds.
Mar 07, 2010 | Belkin N1 Vision Wireless Router
Hi I have one wireless router N1, I need change my password , but I forgeto ,,,,,You can help me
Use the reset button of the router, to change the password into factory settings.
Here's the manual for your Belkin router.
The reset button can be found on Page 13 of the User Guide Manual, this is the instruction on how to reset your router.
There is no password by default.
Note: Using the reset button will delete all the settings of your router that entered by a user, be sure to put back all the settings according to your internet provider setup connection.
Jan 31, 2010 | Belkin (F5D8231-4) Wireless Router...
Forgot my password to my belkin n1 wireless router
You can always reset the router to factory default settings. Keep in mind you WILL LOSE any changes you have made (whether it be wireless configurations, port forwarding settings, etc). But, if that doesn't matter to you, resetting it will allow you to start from scratch. You must know what your Internet settings should be: whether dynamic IP, static IP, or PPPoE so you can get back online.
However, if your question is "What is the wireless networking (WPA) passphrase?" you can change that if you log into your router and adjust the wireless settings. You would need to do this from a machine that is already has connectivity or hard wire the laptop to the router. To do this type into the address bar in Internet Explorer of a connected machine. If you have never adjusted this, the password should be blank and you can just proceed.
Navigate over to wireless settings and the security setting and change the passphrase to whatever you want. If there were any wireless computers working on the network previously then you will need to update the passphrase on them to reconnect.
To actually reset the router, there should be a small pinhole button labeled "reset" which you will need to depress for at least 30 seconds, probably more.
The manuals and troubleshooting guides over at will probably be very helpful.
Nov 13, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
My Belkin N1 (F5D8232 ver.1.0) reset's randomly
try upgrading the firmware. if it doesn;t help, the router is brick.
Sep 10, 2009 | Belkin N1 Vision Wireless Router
Forgot password to login
the only way to bypass it is to reset all your settings:
1. find the reset button (it's a small hole the size of a sharp pencil)
2. press on the rest button for at least 10 sec.
3. login with the factory default login.
Apr 14, 2009 | Belkin (F5D8231-4) Wireless Router...
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Connecting second laptop to my Belkin Wireless G router
I don't know the model of your router this would be very helpful. Most routers have a reset button on the back of the router. This will reset your router back to factory default settings.This will reset the pasword to default usually "admin". You will need to set up your router all over again. Let me know the model and I can send you a link for installation of your router.
Jan 09, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
251 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
