Question about Acer AL1716 17" LCD Monitor
ACER AL 1716
I HAVE AN ACER AL 1716 FLAT SCREEN MONITOR. WHEN I BOOT UP THE COMPUTER, THE SCREEN LIGHTS UP WITH ABOUT 50 VERTICAL LINES IN ALL DIFFERENT COLORS. IT DOES THIS FOR A FEW SECONDS AND THEN YOU EVENTUALLY SEE THE "DESKTOP" BUT IT LOOKS LIKE THE DESKTOP IS GOING 100 MPH BOTH VERTICALLY & HORIZONTALLY. THIS MONITOR WAS ORIGINALLY OWNED BY THE COMPANY THAT I WORK FOR AND WHEN IT STARTED DOING THIS, THEY DECIDED TO REPLACE IT AND SAID I COULD HAVE IT SO I TOOK IT IN HOPES I COULD REPAIR IT.
THANKS!
  • Bay Boy May 09, 2008
    I came home & turned on the computer & found 1 vertical straight line. I have rebooted, turned the LCD off & it is still there. How can I fix this?
    Any help will be useful. Thanks
  • 286 Answers
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Posted on Mar 28, 2008
SOURCE:
Colored vertical lines on my monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Dec 08, 2013 | Acer Computers & Internet
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Acer AL1716 17" LCD Monitor Logo
358 people viewed this question
Ekse
Alun Cox
