Question about Bosch Nexxt WTMC 3300 Electric Dryer
E 01 display and beeping
The dryer runs for about 3mins and then beeps and displays an E 01 and stops drying....
    President:
  • 1,382 Answers
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
Posted on May 10, 2010
  • jamescarball
    jamescarball Feb 10, 2012
    Reset the computer
    Unplug for 10 Sec
    Plug in for 2 -3 sec
    Unplug for 10 seconds
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
After few seconds basket indicators apear on display with beep sound then it stops rotating!
Could be overloaded. Try running it empty. If it runs put in half a load and see if it dries.
Jan 04, 2014 | Siemens Dryers
The diswhasher won't stop running
The motor in the front is the dryer motor. This will keep running until the dry cycle is complete. If it is beeping and there is no other display or light flashing then this motor is faulty and needs replacement.
Dec 15, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer beeps running
Hello Biff
You should the the following.
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
Best Regards
Neciforo Llanto
Sep 21, 2013 | Kenmore Dryers
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
724 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
