Question about Panasonic NN-S505 1200 Watts Microwave Oven
The dish inside the microwave has no movement. It normally moves
  • 31 Answers
If power in on. Just check out to see if the plastic conection may have broke that conects the dish and holder to motor.
Posted on May 09, 2010
My microwave num BR is have a accurate time and moving inside plate with normal sound but it doesn't warm the things
You could have an open high voltage rectifier, or an open high voltage capacitor, or a defective magnetron. If you had a higher than normal noise level, then one of these might be shorted.
Jul 30, 2016 | Microwave Ovens
Why does our new microwave not work? Can set the time and it counts down when we have pressed start but does nothing else.
There is a big fuse inside that thing. Check to see that it is not open. Could be that the magnetron, lite, and dish are all on the same circuit.
Sep 21, 2015 | Daewoo KOR6N9RR Microwave Oven
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
I hv got a haier microwave model HIL 2810EGCB can i use aluminium dish for baking cake
No! it will cause arcing inside of the microwave oven and destroy the magnetron.
Mar 15, 2012 | Haier 1.1cf Microwave- White Microwave...
Put a potato in microwave it caught on fire dish broke no power to the microwave...did I kill it for good or is there a reset button on it...the microwave in build into my cabinets back of microwave is...
When cooking a potato in the microwave Without puncturing it with a fork... it definitively EXPLODS braking the CAROUSSEL PLATEAU and probably damaging some delicate electronics inside, (you have to pearce the potato with a fork to let steem out when cooking) if you are lucky it could be just a blown fuse inside, have it checked by a proffessional (there is normally no reset for a microwave oven exception maiby for the control panel)
Jan 14, 2011 | GE Microwave Ovens
The top plate inside the microwave sparks while cooking. We checked the dish we were cooking with, the papertowel that covered the dish. What could be causing this?
The wave guide could be dirty or damaged. Dirty oven interior can also cause sparking. The wave guide is probably not dirty if it's not on the interior of the oven . Some are behind the interior wall .
Mar 28, 2010 | Whirlpool MH7140XF Microwave Oven
Exhaust fan has stopped working Need to troubleshoot
Even though this is a pain, I need to suggest that you perform the following:
Remove the microwave from the mounting position as follows:
1. Place a cardboard box of sufficient height to have the microwave rest on it with no more than about a 4-inch drop. Cover the box with a bath towel.
2. Using a power screwdriver, remove the 2 mounting screws located in the overhead cabinet base. (microwave front will tilt down onto the box)
3. Firmly lift on the rear of the microwave to unhook it from the wall mount bracket.
4. Once removed, pull some slack on the power cord.
5. Slide the box and microwave forward (toward you)....enough to see the fan blades
6. Place a small cup of water in the microwave and press quick start (30 seconds)
7 Look at the fan blades. If NO movement, open door. Hand rotate blades a full turn to ensure free movement.
8. Restart microwave. (fan blades move - Yes/no)
If No, check power cable that supplies internal power to fan. Be sure it is connectied.
If yes - but only a slight movement - it is clogged with grease...remove it and spray with lots of Ammonia to clean fan elements. Shake excess moisture off. Retest.(fan blades move - Yes/no).
If yes, reverse removal procedure and enjoy....
If no, Replace fan assembly
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-S505 1200 Watts Microwave Oven Logo
37 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
