I HAVE EMACHINE t2824 i have change the motherbroad now it wont turn on
  • 493 Answers
- Check the connections of motherboard, power supply etc. if you changed something wrong.
- What is your motherboard's model? Is it compatible to your system? I hope so.
- What is your Operating system? (XP?) Try to log in Safe Mode (one of the selections). Press F8 during startup, Select "Last Known Good Configuration" option ( This option starts Windows by using the previous good configuration.)
- Then install your new motherboard driver. (You can use control panel menu, Adding device drivers)
Hope this works.
Posted on May 09, 2010
Flash player
just go on the net and ask for flashplayer download make sure you pick the free one.
Apr 06, 2014 | E-Machines (T2824) PC Desktop
T2824 emachine turning on and off by itself. Sometimes it will be on for a 3 or 4 hours and go off and then turn its self back on in a couple hours later or even the next day come back on. I replaced the...
Take the side cover off and use compressed air to clean the dust off the heatsink fins atop the processor. If that doesn't help, take any cowling off, and make sure no dirt is plugged between the heatsink fins.
Feb 15, 2018 | E-Machines (T2824) PC Desktop
I need a phone # for emachine custmer service the phone i have is not a correct #.
They took down lots of their support numbers. Have you tried the following channel with the online chat?
http://www.emachines.com/support/warranty.html
Apr 27, 2010 | E-Machines (T2824) PC Desktop
I have a emachine T2824. It will not boot I have a recovery disc but it wont boot from it. Keep asking me for a password. Windows XP pops up but it goes away and then a blank screen with a flashing line in...
When you first turn on your system look at bottom of screen it should give you info to enter setup, more than likely it will say F2 to enter setup. If you are able to enter setup check Boot devices and change from hard drive to cd rom than you will be able to boot to recovery disc. Be careful that you write down any changes you make so you can reverse them if you have any issues. it is fine to leave boot to cd.
Feb 27, 2010 | E-Machines eMachines Desktop PC
How do i reboot my emachine w3609
I'm not sure what your problem may be but to reboot your pc, you can do a couple of things; just power your pc off, press at the same time Alt, Del, and Ctrl buttons.
Good Luck
C2Solutions, Inc.
Nov 09, 2009 | E-Machines (T2824) PC Desktop
Replacement of hard drive
The first link is to download the step by step instructions on how to replace the hard drive on your model. The second is the contact link for e-machine ,as I found no restore disk as a download.
http://www.emachines.com/support/service.html#eurpp
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2824
Apr 22, 2009 | E-Machines (T2824) PC Desktop
Restore emachine
Your machine has two ways of repair: SYSTEM RESTORE and SYSTEM RECOVERY. System restore is a Windows utility that rolls the machine back to a point where the machine worked before the problem. System recovery is an eMachines tool that puts the machine back the way it was when you first got it. Restore wont delete your data, recovery will and can. If the problem is catastrophic, and youve backed up your data off of the machine, use the recovery option. Your recovery partition (or a recovery disk) is needed to do this, and it involves pressing a key while the computer boots up. Check your documentation for your model of machine.
Mar 24, 2009 | E-Machines (T2824) PC Desktop
I need hepl with setting up the bios on a T2824 Emachine
Hit  f 8 when starting computer. When you get into the BIOS setup screen choose the default settings. Find the start priority and put the cd driver first.
Jan 24, 2009 | E-Machines eMachines Desktop PC
EMachine T2824 does not turn on. Power cord/power supply seems O.K.
There are just too many eMachine models to be familiar with every one, however, as a preliminary inspection, remove the side panel, and turn the computer on to see if you see a green "Health" light. This will give you an initial clue as to how to pursue the problem. eMachines have historically had power supply problems. If you do not see a green health light on the motherboard, then your power supply is defective. A power supply supplies various voltages + - 5V, + - 12V ,etc. A power supply can be easily tested by a local shop with the proper test equipment. You might start there if you are a DIY! Short of that, you can purchase a power supply for under $65.00.
Nov 20, 2008 | E-Machines (T2824) PC Desktop
Mobo problems
Assuming the power supply is ok, and the pc is a few years old, it could be a flat cmos battery so check for the disc shaped 3V battery and see if it's flat. Whilst you have done that look for the JBAT1 terminal and put jumper on pins 2-3 for a few seconds then back to 1-2. Look at the capacitors (tube shaped things) for the tops and sides swelling, if so mobo needs replacing. You need also to check the power supply leads to the motherboard and check its connected to mobo ok. Start up pc if it will and set the time and date in standard bios settings.
Jan 24, 2007 | E-Machines (T2824) PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
