FixYa.com
Tags:
Sony CDP-CX210 200-Disc CD Changer
Sony CDP-CX455
posted by LJanacek on Mar 28, 2008
I have a a Sony multi disk player which I love. However all of a sudden one channel has a murky sound. I check the speakers, cable...and came to the conclusion that it is the output to that channel. Perhaps the laser is dirty. Would a optical cable correct this? Do you have any thoughts or sollutions.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by robotek, posted on Mar 28, 2008
Hi there, what happens when you swap the rca connections left for right on the back of the Sony. Does the fault go to the other channel?
awaiting your advice.
regards
Graeme
Best Solution
posted on Mar 31, 2008
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I swapped the plugs, which just resulted in a fuzzy sound from the other speaker. It is not the speakers, since I tried the headphones with the same result. It is not the plug, since I changed the plug. It is not the amp...since I checked this out also. It is the output from one of the analog outlets on the back of the amp. That is why I wonder if a optical connection would resolve the problem.
Rating Locked! (?) LJanacek has rated this solution as Thanks for Trying
Solution #2
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 475 votes
did you have any luck with swapping the channels to determine if which is bad, cd or system?
regards
Graeme
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these CD Players problems?
CD Players
Sony CDP-C735
CD player powers off on its own... Answer This...
CD Players
NEED TO FIND A MANUAL
I recently bought a LG Stereo... Answer This...
sony cdp-cx455 internal blue...
The intenal blue light in my... Answer This...
it stopped and wouldn't play...
my 200-disc cd changer was... Answer This...
the CD player does not play...
Repair Service
Find CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
