Question about Quartet gbc ShredMaster 2260X Cross-Cut Shredder
My shreadmaster 2260x not working. the red light blinks as if there is a jam. i've opened top, and cleaned. nothing appears to be jammed. what can i do?
  • 7 Answers
SOURCE: I NEED TO CONNECT MY I MATE K JAM WITH MY LAP TOP
connect to computer then the popup comes up and search there and it comes up!
Posted on Apr 01, 2008
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
SOURCE: Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
  1. Close all the covers.
  2. Check in the paper tray for paper.
  3. Check for the toner cartridge.
  4. Remove paper tray, toner cartridge and open the back cover for any paper jam.
  5. Please make sure that only supported paper type and size is loaded.
  6. If printer prints after opening and closing the door, try to load different type of paper.
  7. Disconnect the pritner from the computer, and restart the printer.
  8. If Red Light lits up right away, there's a possible paper sensor problem.
  9. If you see a Green Light, press and hold down "Cancel" button for 4 seconds and then let it go.
  10. If it prints the demo page fine, connect the printer cable to a different port or replace the printer cable.
  11. If it goes back to Red Light, pick-up roller inside the printer is defective.
Posted on Aug 23, 2008
websnail
  • 419 Answers
SOURCE: Epson R230 blinking 2 red lights after cleaning clog
I'll need a little clarification to diagnose this but my guess is that you have something blocking the path of the printhead.
There are two possible diagnoses...
1. Service error: This is when the waste ink pads are full.. It's indicated by both ink and paper lights alternating with each other. I doubt very much this is the problem...
2. General or "Fatal" error: This is when something stops the printhead from doing its job and usually follows something like a paper jam where something has been left behind or been pulled out of alignment when clearing the jam. I'm betting on this being the case.
Here's a few things to try.
  • Check to see if the printhead can move the full width of the printer. Note any areas it has problems reaching like the parking pad.
  • If you can identify an area that it's stopping at, note the direction of travel and see if there's anything in the way or out of place in that direction.
    - A common one is a bit of paper that's become covered in ink making it hard to see, sticking up and blocking the path.
    - Another is the parking pad or cleaning station being pulled out of position.
  • Check that all the rollers and paper guides are uniform and there's no obvious lifting. Sometimes they can be pulled out of alignment and just need nudge (carefully!) back into position.
Anything else is going to rely on you reporting back with a bit more information in detail as to where the printer is stopping, and any additional observations... The more you can provide, the easier it will be to solve the problem.
Regarding the solution from top_class... This would do more damage and solve none of your problem.. I suggest you ignore it.
Posted on Mar 16, 2009
virtualhost
  • 2185 Answers
SOURCE: cannon imageclass mf3240 laser printer paper jam
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Posted on Jan 09, 2010
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
My GBC Shredmaster 2260X is jammed and I can not clear it. The teeth try to rotate when stimulated but something is jamming it. Where can I go for service? I am in murfreesboro, TN.
you can do it yourself!! it take a little bit of time and patience. do it in an area that you can clean easily. take off and unplug the top, turn upside down, get a flat screw driver and start removing all the papers in the teeth area. from time to time you will need to put it bank and turn it on and make it go forward and reverse.
Sep 15, 2008 | Office Equipment & Supplies
Flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
 If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
 If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
Jun 07, 2008 | HP Color LaserJet 2550n printer + HP Color...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Blinking Lights
Do you have a paper jam? If nothing is wrong it may be internal hardware error. Call Samsung for help.
Apr 04, 2008 | Samsung ML-2510 Laser Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Quartet gbc ShredMaster 2260X Cross-Cut Shredder Logo
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
