Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Water not working
Yes it males ice just no water we moved it and had to take doors off it every thing is pluged in water hooked up but when I push the dispencer no water no nothing I pushed the reset Boton and still no water but pllenty of ice is being made
  • 316 Answers
Did you reconnect the water line at the bottom of the freezer door? is the water line to the door kinked?
Posted on May 09, 2010
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
I get water from the dispenser but no ice
As you open the freezer door you will se a wire on the side of the ice maker. It is there to stop the machine from making ice like a float in the toilet. It may have been bumped move it up or down until it clicks. it should go to work making ice now if not the valve in the back of the frig is pluged or bad. If you do not have a water filter it is pluged. The filter is cheep and easy to replace so I would turn the water off to it and replace the filter any way most are neglected.
Aug 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
When you press the ice dispenser no ice
the switch you push activates a couple of things. One is a solenoid that opens the door the other is a relay that moves the ice to the crusher.
Since you aren't hearing any sound....and are not getting any ice, I would suspect the switch is bad.....
But before you start taking things apart....try pushing it with your finger rather than a glass.
Check for the length of travel? can you feel or hear a switch click?
Jul 07, 2009 | Frigidaire FRS6R5ESB
Replaced selenoid water just keeps pouring out
Water dispenser seal in the door needs replaced.
Jan 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water not getting to ice maker
yes repl the water valve at the back of unit but first i need you to get an insulated wire strip the endes of it and remove front cover from ice maker lookt for th letter t and h insert the wire inside the holes and look at the ejector inside mold is it starts moving let it finish cycling it no water repl valve if it does not move repl module but is better or ice maker alomost same price
Oct 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
94 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
