Question about HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook
Hello my laptop having unable to startup problem.repair program at the startup unable to fix the startup problem.window goes blank.circular window icon don't pop up.even after format.problem still persisting. so please suggest instruction so that i can fix the problem. thanking u in advance. reply soon as possible
    Guru:
  • 1,481 Answers
If you can see some msg after power on then screen and CMOS BIOS is OK...
try changing the CMOS battery inside....(battery model will be CR2032 i guess so...it will be aprox the size of a dime(US 10 cent coin size)
or
RAM is corrupt...change the RAM cards inside...ensure that the new RAM is compatible...
pls leave a feedback...
reg
Posted on May 10, 2010
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Hello.
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
Black screen on Acer aspire 1642
Try below steps.
1. Check computer in safe mode (Tap F8 while booting)
if works fine in safe mode , check startup programs and services.
2. Run antimalwarebyte in safe mode download from http://www.filehippo.com/download_malwarebytes_anti_malware/download/6a5b2c1adb0e88e84ab39920bab1ebbd/.
3. Try to repair using repair your computer option (windows 7,8)
Dec 02, 2011 | Acer Aspire 1642WLMi Notebook
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
run in safemode Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Sep 22, 2010 | HP Pavilion dv2000t Notebook
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Windows Vista starts up but then after I type in my password the screen goes blank
Although the sounds of this problem is more of a software issue than hardware, one of several things could be the cause ... faulty RAM (freezing issues), battery or mobo (power supply issues), corrupted Vista update installs (no surprise there), faulty startup programs, infections in the system ... I suggest trying these options: 1) run a detailed hardware scan to find any faulty hardware. 2) turn off laptop, take battery and AC adapter out, hold the power button for 10-30 sec then plug everything back in. 3) run a "chkdsk /r c:" on the command prompt using any Vista disc repair mode to find and fix possible corrupted O/S files then go to restore mode and load a time and date before the incident happened. 4) see if you can get into safe mode without the blank screen issue, go to run and type "msconfig", go to "startup" tab and turn off any programs that looks out of place, then go to "services", click on "hide all ms services" and disable services that looks out of place. 5) scan for infections. If you have Norton or McAfee, remove it ... and if you remove it ... be sure to use their removal tools located on there respective website. They usually leave residual files behind after removal using conventional means (ie Add/Remove programs) If none of these help ... backup your stuff and do a recovery!
Aug 19, 2009 | Computers & Internet
Vista Home won't boot
NeoSmart Technologies offers a download called Vista Recovery Disk in .iso format. Download and mount the iso with your favorit burning program. Boot to the cd to access the recovery center. Hopefully you'll be able to repair your Windows Vista installation or restore to a known good configuration.
Good Luck
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
I have an Acer aspire 5610 and all of a sudden I am having a problem trying to boot up. When trying to start, I get a screen that says WINDOWS FAILED TO START then it asks if I WANT TO LAUNCH STARTUP...
This may seem difficult but the cause is simple. Your computer is unable to locate a DLL file (dynamic link library) that is key for windows to start, unfourtunatly the only way to fix it is to reinstall windows. it will not affect your data, and all your programs will be there after installation. Just boot from the cd and follow the instructions on your screen.
Mar 09, 2009 | Acer Aspire 5610-4648 Notebook
HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
