Question about Kodak EasyShare M863 Digital Camera
My easy share turns off and then back on again. I replaced the battery and charged.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
My kodac easy share c180 wont turn on
This kind of issue might happen. Remove the battery from the came and then press&hold the power button of the camera for 30 seconds.... Put the battery back and then try to turn it back on.......Hope u are sure that the battery has enough charge. If the step does not work try some other alkaline or lithium batteries if possible.
Feb 17, 2011 | Kodak EasyShare C180 Digital Camera
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Mar 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
My Kodak Easy Share M340 won't turn on!
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge. This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 04, 2010 | Cameras
I have a Z730 Kodak Easy Share. I was told by a
True. Camera batteries, along with cell phone batteries, have something called a memory. What's best to do is initially when you get it to run it until it won't turn on the first time, charge it up fully and run it to empty again, and on the third time it should have developed a battery memory to last that long. By putting it on the dock too early you are setting the lower limit of the battery and when it says empty there could still be up to 15% left on your battery. Good luck and I hope you have fun with your new camera!
Dec 02, 2009 | Cell Phones
When i turn my kodak easy share C813 on it says
take out the battery and set your mode dial to auto and put the battery back again and turn on your camera.
Aug 19, 2009 | Kodak EasyShare CD33 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera will not turn on and battery is fully charged
Hi I am Vortash I know this might sound silly but check the battery is in the correct way round .. if your like me and changed the batteries to my easy share I forgot a couple of times and put them in the wrong way round ..( even we make mistakes ) reversersal of the batteries cured my problem and added to my embaressment lol .. other than that check the batteries havent leaked and if they have look in the battery compartment for signs of damage rust etc .. and if you are still using the easy share battery that came with the camera .. it might say it is charged but may not be mine was dead and wouldnt charge afyer about 6 months use .. Regards Vortash
May 17, 2009 | Fuji FinePix F10 Digital Camera
My kodak easy share Z1275 won't come on
I used mine for 1 month & took 300+ pictures, loaded them to my PC. Took 10 pictures over a weeks time & while reviewing them, the camera powered off. I replaced the batteries, tried the "charged" recharchable set & the thing wont power up.WTF!!! .....the **** part is, we're broke & have a baby due any day.....we won't get pictures of our newborn.......signed - upset with Kodak....
Mar 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
