Question about AT&T Siemens S46 GSM Cellular Phone
I am not able to get incoming cals
Although I am able to ring out my phone is not ringing in. I have tried ringing using my mobile but it just flashes red straight away without ringing. Have I (or my kitten) pressed something by accident?BT have said it is not an outside problem.
  • 88 Answers
Check your call forwarding settings to make sure the call forwarding is not turned on. Hopefully this solves the issue.
Posted on May 10, 2010
Hanging problem
wellcome, you need to flash in new memory to the phone.
Jul 28, 2009 | Lands Phones
Problem with incoming call ring alret
It may change due to your profile or because of your memory card (if u have one).
Apr 22, 2009 | Nokia N73 Cellular Phone
Phone doesn't ring for an incoming call
pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Feb 28, 2009 | HTC P4350 Smartphone
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
Feb 16, 2009 | Nortel Meridian M7208 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
You may have already done this, but the first step is to check your various settings.
Go to Start > System Tools > Settings
First, go to the "Profiles" menu and make sure your phone is NOT in Silent mode.
Then, if your phone still isn't ringing, go to the "Sound" menu and make sure your Ring tone and various other sounds are set appropriately.
Finally, you should try turning off and on your phone and seeing if this corrects the problem.
If none of these tasks work, there may be a hardware issue with your phone and you should bring it to your carrier's local store and ask them to fix or replace it.
Aug 04, 2008 | Samsung SGH-D500 Cellular Phone
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
Ringing problem
try via using another profile in settings...option is there...else restore ur handset.....if that silent mode does not remove then do flash upgration....speaker is fine if u r able to hear the incmoing call.
Aug 05, 2007 | Nokia 6610i Cellular Phone
AT&T Siemens S46 GSM Cellular Phone Logo
69 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
