Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Both refrigerator and freezer are not cooling. Also making a humming noise
  • 316 Answers
If they are not cold at all, you may have a compressor or starter problem. if its only somewhat cold, check all fans.
Posted on May 09, 2010
  • 213 Answers
SOURCE: Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Posted on Nov 27, 2007
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 219 Answers
SOURCE: Freezer Fan making humming noise until Turbo Cool is pushed - GE
yes need to replace
Posted on Mar 19, 2009
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
  • 10 Answers
SOURCE: Amana refrigerators is not staying cold and
What you have is a compressor not starting. It is kicking off on the overload protector. This is caused by a failed relay or the compressor being locked up. Amana does have some models under a recall for that relay. Call (866) 533-9817 to verify. If it is a locked up compressor there may be a 5yr warranty on it. You can call Amana directly to verify that too.
Posted on Jul 30, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Freezer suddenly making noise
The freezer is not defrosting and ice has built up to hit the fan... soon it will not cool at all...
This tip gives you an overveiw of the problem..
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 24, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
