Brother 7820 prints everything slanty, I checked paper tray and paper feeder everything is straight but the print comes out slanty,when I make a copy of that it is even more slanty, any suggestion?
  • sales519 May 09, 2010
    I will try this and see if it works, it does make sense.
  • 2,427 Answers
Yeah,, the feed threader wheels that pull the paper out of the tray ,, has a few gears on it.. these gears get worn out,, you have to replace the gears.. In the mean time if you full the feeder back and forth, you will realise it has a slight play on it.. rock both foward as far as it will go and hot glue (or epoxy) them in place..
Posted on May 09, 2010
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    The copy comes out of the printer out of alienment. I have checked the tray and everything seems to be ok. ????
    goto ink management and select print alignment... once printed, it will ask you whether you would like to align the print head or accept the current setting... select alignment and once print out...select the best print out ..normally the one with the most straight line..
    May 22, 2010 | Brother MultiFunction Center MFC-440CN...
    How to print using ADF feeder?
    You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
    Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
    Image print on paper slanting
    Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
    Jun 05, 2009 | Canon NP 6545 Copier
    Paper Jamming when trying to copy or print
    please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
    If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
    May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
    I can't use Print function for ByPass or Document Feeder?
    The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
    Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
    I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
    lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
    May 15, 2008 | Brother Office Equipment & Supplies
    Printing is crooked
    if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
    Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
    Not printing, says check original
    Can be a document feeder jam.
    Also can be that you are trying to copy an odd size original that it doesn't have the paper-stock for. in that printer it can be caused by not having the paper trays set correctly or using the menu to force it to try printing on something like legal size paper when it only has 8.5/11
    Try resetting the printer with a power off and make sure the paper try is set to 8.5/11
    Apr 24, 2008 | Brother MFC-8440 All-In-One Laser Printer
    Auto feeds crooked
    Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
    Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
    19 people viewed this question
    jasbo
    jasbo
