Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My screen isn't showing a picture?
I think itis because I plugged in my ps3 but now my tv seems to be burnt out and not showing a picture what should I do?
  • 1,030 Answers
OK first question ... Does the front led flash... does it make any noise... this answere the is it a fuse question. then the troubleshooting begins
what was it doing before it went dead...
Posted on Mar 28, 2008
Norcent model LT-2725 TV to ps3?
Check the video out settings of PS3.
Jul 27, 2012 | Televison & Video
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
When I connect the PS3 to my Toshiba Tv, it is not showing a picture or sound, I don't know what I am doing wrong...
Have you plugged the hdmi cable in to both the TV and the PS3? or... Have you plugged the composite cables into the PS3 and TV, if so. Turn off the console, now hold the power button until you see the screen pop up, It most likely just needs to be reset!
Mar 12, 2011 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable to playstation and the tv, i get no signal! when i plug that 3 different colour cable. i get good graphics.. how to fix my hdmi input for Ps3
plug both cables into tv select the input on tv that has the three different color cable plugged into it use this connection to navigate the menu on ps3 go into display settings and choose the option for 1080 p or 1080 i and then choose the input method of hdmi after doing so your picture will go blank you must then select the input on the tv that has the hdmi plugged into it your screen should then show the picture you must do this quickly because you only have 30 seconds or so to save the new settings before it resets back to the old output settings. click your x button to save and you should be well on your way to better graphics using the hdmi on your ps3!!
Dec 06, 2010 | Sony Video Game Consoles & Games
Iam not able to get a picture from my hdmi cable, but can still here sound. tried three different hdmi cables... please can you help...
1. Your Connections Are Faulty
Quite often, the cause of the no picture problem is a simple one - loose cords. Make sure that the cords are plugged in tightly, both on the TV side and the PS3 side. This is especially true with the HDMI cable connection on the PS3. Often, it looks tight, but you still might need to wiggle it a bit more to seat it correctly. Along the same lines, make sure that the cords you are using are new and match the connections properly on both the TV and your console.
2. Wrong Connection Settings
If you are using the HDMI/DVI cables and you don't get any picture, make sure to check your video ouput settings. If your PS3 thinks you are using standard A/V cords to connect to the set, you'll have issues. The opposite is true too - if you are using the A/V cords and your PS3 thinks otherwise, you'll have the same no picture problem. Make sure you settings match the types of cable connectors you are using.
3. Wrong Resolution Setting
This is also an easy mistake to make that can result in no picture showing on your television screen. For example, if you've been using your PS3 with an HDTV and then try to hook it up to a standard definition television set, you'll encounter this issue. The cure is simple; just go into your settings and switch back to standard resolution and then restart your system. The 720p resolution is the default setting and this should work for most standard definition televisions.
Nov 18, 2010 | Sony Playstation 3 (PS3) Console
PS3 Power Surge Help!
hi there try using the ps3 as audio-cd play(blind, without screen)
with any other tv to make sure soun still is coming...
if there was a flash or circuit destroyíng the yellow(video)plug,
either the cable has been destroyed or the short backfired even into the video module of the psx3.
try exchanging the cable, if that doesn't do any good, the video module got smoked...
let a technician repair/replace it or you think about becoming the happy owner of another brand new psx3
good luck!
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
I can only watch Blu-Ray discs in letterbox format and no other
I had the same problem. What you need to do is change your aspect ratio on your TV. Should be on your TV remote. While you wont get a full screen mode you will get very close. I cant remember what aspect I switch my plasma too I think Full mode. Anyways hope this helps.
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Aug 24, 2007 | Sony Playstation 3 (PS3) Console
Picture won't show up.
well make sure that the av cable is in tight in the back of the console and if it is wiggle to see if u can get a picture or somthin
Aug 03, 2007 | Sony Playstation 3 (PS3) Console
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
