Question about Pioneer PRO-119 60" Rear Projection Television
Pioneer Pro-97 Cable Problem
I have a Pioneer Pro-97 rear projection tv and the cable won't work on it. The cable stopped coming in about a month ago, but I learned if I left it on a video input for about 20 minutes then switched it back over it would work. Eventually some stations began to cut out though every couple of minutes for a split seconed.However, last week every channel started cutting out for long periods of time and now none of them come on. The video inputs still work great, but its just the cable thats messed up. Is this a tuner problem, RF switch problem, or what? I'd appreciate any help I can.
WILL NOT SHOW A PICTURE
Posted on Dec 23, 2008
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
A very loud static pop noise
i would suspect that you may have a defective coupling capacitor in your preamp or amp, try using another source input or and a different amplifier to help localize the fault, I do not suspect the cable as being the fault, and is more likely and amplifier problem
Apr 27, 2010 | Pioneer PRO-200 60" Rear Projection...
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
NO PICTURE FOR MY CABLE
check your hookup and check your input button on the front of the tv hope this help's Rocky
Jan 20, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
COLOR
Are you using the RGB cables (component video) from a cable box to your TV if so check the red cable.
Jul 29, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer PRO-710HD 64 in. Rear Projection
could be your projection lamp.. check the manual for how to check
Oct 01, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer Pro-200 60" Rear Projection Color Adjustment
after market duplicate remotes are reasonably priced-search tv remotes on-line.
Sep 26, 2007 | Pioneer PRO-200 60" Rear Projection...
Televison & Video Logo
144 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
