Question about Amana D565M Dehumidifier
The unit turns on, but indicates the room is at the lowest humidity setting (30%). Therefore, it won't turn the compressor on because it believes the room has reached the correct humidity. Any solutions>
  • Amana Master
  • 43,501 Answers
The humidity sensor or the humidistat is probably the problem...
Replacing these can correct the problem, but may cost more then the dehumidifier is worth...
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifierThe unit turns on, but indicates the room is at - 2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 10, 2010
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
Whirlpool AD70USR0 Dehumidfier - Our basement is extremely humid and the dehumidfier sounds and looks like its running but collects no humidity...any suggestions why?
If it is very cold some of these consumer units will not turn on the compressor. If the unit suddenly stopped working and the temperature is room temperature I would guess a refrigeration issue- either a leak or bad compressor. Make sure the "full bucket" indicator light is not on- the condensate bin may not be plugged into the unit properly.
Sep 25, 2011 | Whirlpool Dehumidifiers
I have an LG model LHD65EBL dehumidifier. The humidistat will not change from 70 when I push either + or -. The fan runs well and the compressor sounds like it is running well Some water comes out when the...
Prt of the problem may be a dirty or clogged air intake filter.
Turn the unit OFF and unplug, it before removing the filter to check and clean it.
You can ether vacuum it or if it's really dirty & clogged, wash it in warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow it to dry completely, before reinstalling it.
Never operate the unit without the filter in place. As this could damage the unit.
Plug the unit back in and turn it ON. Try lowering the humidity extraction level now, using the arrow down button. For a very damp, humid basement application 35% is a good setting to start with for several days.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD65EBL Dehumidifier
Will not regulate humidity correctly. I set it at 60% and it is still running when the humidity in room reads 45%. I have confirmed this with a separate humidity gauge.
It may just be the fan running and not the compressor. Some unit's are designed that way, so that air is constantly moving and when the humidity level rises above what you have it set on, the compressor will automatically turn ON and remove that moisture. Wants it's back to where you have its set, the compressor will turn OFF. Check your Owner's Manual to see if your model has that feature.
Aug 06, 2011 | Comfort-Aire BHD-501 Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
I have my Edison 40 running at the highest setting (lowest humidity) and it isn't lowering my humidity. The hose to my floor drain emits only a tiny drop once in a while. Is there something for me to...
Ronald, first,check the air in take filter for dirt and/or clogs. Also check your drain hose for a blockage, as well as the hose connection on the unit. In addition, if the cooling coils are dirty, this will cause the unit to strain to keep up. You should be able to access them, after you remove the air intake filter. Clean them with mild soap and warm water. Rinse and thoroughly dry them, before applying a very light coat of WD40. CAUTION: BEFORE ATTEMPTING ANY SERVICE ON THE UNIT, TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
I assume you have one of the older Edison 40 Dehumidifiers, that doesn't have an LED readout. And this is where it can sometimes get confusing, when setting the humidity extraction level. Maximum doesn't always indicate the maximum extraction level. And in your case, I believe if you set it on Minimum, you would get better results. Always allow a minimum of 12" clear air space all around the unit, while in operation.
If, after you troubleshoot the above things and want to do a good in home test of the unit. Move the unit to the bathroom, plug it it in, turn it ON and set it for Minimum. Turn the shower ON hot enough to generate steam. Do Not turn the bathroom exhaust fan ON. Close any window(s) that may be open. As you exit the bathroom, close the door. Wait 15 - 20 minutes before returning to the bathroom. Then turn the shower OFF and allow the dehumidifier to run additional 5 minutes. Turn the unit OFF and check the bucket for signs of water. If you find some, the unit is working as it should.
If you find n water in the bucket. The unit's compressor probably needs a recharge of refrigerant gas.As the level may be low.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Edison 40 Pint Dehumidifier
Our dehumidifier is not taking moisture out of the air and putting water in the bucket but everythings to be running fine
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. Also make sure that the room is warm enough. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work. Add heat to the room if necessary to improve the unit's performance.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
Hope that was helpful. Thank you very much and good luck.
May 23, 2011 | Maytag M7DH65B2A Dehumidifier
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
My dehumidifier only the fan runs
Are you sure you have the humidity level set low enough for the compressor to turn on? If not, the fan may run anyway.
Your unit may be designed to run the fan continuously despite the fact that the room has reached the set humidity level. This design feature is intended to keep the air moving which helps mildew problems in both the room and on the surfaces of the dehumidifier itself. Check your manual.
Aug 31, 2009 | Dehumidifiers
Amana D565M Dehumidifier Logo
205 people viewed this question
Top Amana Dehumidifiers Experts
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
