Question about Dacor ETT3042S 30 in. Electric Cooktop
I don't have a manual and this has happened once before. The burners were on and operational. About 20 min. later I went to turn on another burner and nothing happens when I hit the on/off area. The only red indicator light ois over the dacor logo on the cooktop. .
  • kathybupp May 09, 2010
    I've got dinner guests waiting.
    It is an electric unit
    Guru:
  • 312 Answers
Find the name of the manufacturer, if you do not have it listed somewhere, then get on google and google the manufacturer then surf thru the web site for service and parts department. If burner is not too new ask about the warranty. Also ask for a manual as well. Most companies have local authorized parts and repair facitlities so find that out too. Darrell S
Posted on May 10, 2010
  • 2,427 Answers
Are you sure you have have enough gas and gas pressure..
Posted on May 09, 2010
  • Rishi Roshan Ali May 10, 2010
    then its a problem with the distribution control circuit,, something I'm not familiar with and maybe another expert here knows a bit bitter,,,, keep requesting new answers and till you get one that works and then accept the solution of that expert that helped u the most.. good luck and sorry i cant be of any help.
  • 728 Answers
You can download the manual for the Dacor HERE. Just click on the tab for manuals and there are a lot that can help you troubleshoot this problem.
Thanks Mark
Tip
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
One of the burners does not light but it does have a spark at ignitor but it is not directed to burner port
Be certain the openings in the burner are free of debris. Boilovers can leave debris in the openings that will harden. Once this happens you cannot get the right mix of oxygen and gas for a flame to ignite. With the burner OFF, you can clean the openings gently with a toothpick to loosen the cooked on "gook." Then when you turn on the burner, the flame should burn off the residue and your range will be "cooking on all four burners!"
Nov 06, 2010 | Jenn-Air JGC8536 Gas Cooktop
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
Ignitor does not spark on first turn as stated in manual. I have to turn the knob past "lite" before flame comes on.
Is it just one burner knob that does that are all of them? If it is just one then the igniter switch built into the burner knob might be out of alignment or loose. This happens most of the time due to a cracked switch housing(made of plastic). This can also happen if the actual burner knob is cracked and/or loose. If all the burners do this then it is just the way the cooktop works. The best way to get the burners to light is by slowly turning them on until they light and not pay attention to the "light" mark. You might need to turn it just past the "light" mark for the burner to come on.
Jan 18, 2010 | GE 30 in. JGP326 Gas Cooktop
Cooktop spark igniter will not turn off
This is usually a bad spark module that is not sensing that the burner is lit. You need to replace it. Is it still under warrantee? Good Luck, Appliance Specialists
Jan 06, 2010 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Dacor ETT3042S 30 in. Electric Cooktop Logo
41 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
