I need a usb cable to hook up my new Lexmark 5000 to a dell modeum. where can i get the cable with the right ends on it?
    Sergeant:
    Champion:
  • 277 Answers
Usually a newly buy printer have also a set of device specially usb cable,, if dont have you need to buy...
Posted on Mar 28, 2008
  • 121 Answers
My best bet is you would have to call a support hotline the number is probably in the instructions with the printer. if you dont have them you should try Lexmark's website and see if you can find anything like that.
What kind of usb plug i need for lexmark8350 to hook my pc
The USB cable would be the standard A/B cable. the port on the back of the printer, is located under the phone line jack. Open the attached URL for the setup guide.
http://www.lexmark.com/publications/pdfs/8300/eng/setupsh.pdf
Mar 16, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
I have hooked it upto a dell desk top and do not have disk how can i make it work
Hi Sam, It should work with your Dell as long as you put in the right driver to suit your operating System. You dont need a Disk because we download the right driver.
First unplug the USB printer to computer cable and go to control Panel/Add and remove programs and uninstall any pre existing lexmark software. Also go to printers and fax's and remove/delete any printer icons that you are not using or apply to your lexmark X3470 printer.
Once you have done that go to this link for lexmark and download the right one to suit what version of windows you are running, if my link doesn't work in you country just go to lexmark's web and go to drivers and downloads for lexmark X3470. Here is another Link just in case i stuffed it;)
Once you have found the right file run the file,a warning will prompt but choose run again, then choose install and follow the instructions on the next page software will tell you to connect your USB cable so do so when prompted by the Lexmark software.
Heres an example for Windows 7 32bit in pics
Choose RUN or save it known location if you using slow internet and then open it.
Second screen priomping warning run anyway as software is from lexmark and just isnt windows certified
Third is Lexmark software starting to install on my machine, note Lexmark X3400 Series is compatable with the "70" version of 3400 series ie X3470
Let me know how you go, or if you need more help
Cheers
soulvisitor
Oct 18, 2011 | Lexmark X3470 All-In-One InkJet Printer
My dell inspiron 531 is not wi fi compatible how do I hook up my lexmark x4550 printer/scanner/copier to it
bring usb wi-fi from market it will turn your computer to wi-fi capable, other wise you need usb cable to connect printer with you laptop and drivers as well..
Nov 01, 2010 | Lexmark Office Equipment & Supplies
My computer won't boot up while my Lexmark X5650 is connected and turned on. Dell computer running XP pro. When I turn the printer off, it will boot.
Try moving the USB cable to another usb port. Ports can go bad; or if the printer interface is bad; it will cause this type of problem. If you want, you can try another cable too. In the end, you may end up having to replace the printer. But, certainly try another port first.
Oct 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Hook up my printer
Yes, you nedd a USB A to B cable.
Jun 28, 2009 | Lexmark E232 Laser Printer
Computer won't recognize new Lexmark X9575 printer
Are you conecting via USB? If so, did you wait to connect the USB cable until the installation advised you to? If not, uninstall the software and driver, unplug the USB cable, reinstall the software and driver, and when prompted, plug in the USB cable.
May 18, 2009 | Lexmark X9575 InkJet Printer
Cord needed to work with our new Dell computer
i have a g85xi my self and you will need to use a cable to connect from the g85 to your usb port on the dell i have a hp wich is basicly the same one end of the cable be square and the other end is a usb end
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Computers & Internet Logo
David Payne
David Payne
