Question about JBL JRX118SP Microphone
I have a JRX 100 I have ran through all of the voltage points and everything is showing up. But there is still no sound. It was running then it powers but nothing. All the voltages are getting through each PCA but nothing. Where would I start to look? I have great DVM and I am a BSEE just lost at this point
  • Mike Dolbow
    Mike Dolbow May 10, 2010
    I have a JBL JRX-100 Bass bin that has no sound. I have checked its self powered amp at the power source and through the circuit but I can not find the problem. I think it is in the pre amp section but with out schematics all i can check is that each IC and transistor is getting voltage. I am not finding the burned out component.
    Can you point me in the right direction in order to check?
  • David Dunn
    David Dunn May 11, 2010
    Can you define the product more precisely? What is it?
    Brigadier General:
  • 8,546 Answers
I'd do some more triage before cutting into the patient.
Do you KNOW the speaker driver itself is ok?
Do you KNOW the audio input is getting through to it from the source?
Posted on May 10, 2010
I need a wiring diagram of a 1960 ford f-100 6 cylinder ignation coil
I don't have wiring diagram for that year.
I don't mind talking to you.
The positive side of the coil gets voltage from ignition switch, the negative side of the coil goes to distributor and ignition points on a points type system.
Some makes and models, when cranking, everything gets full battery voltage. When it starts and you release the key it springs back to the run position. In the run position, voltage to the coil may go through resistor block or resistor wire, the purpose is so the points on a points ignition doesn't have to deal with full battery voltage all the time. Helps the points last longer.
Just my opinion.
May 30, 2017 | Ford Cars & Trucks
Battery chargeing issues
You should not have jumped it from there, there are hook up points to jumper the car under the hood. You may have damaged the alternator or the computer that controls the output voltage. At this point you need a dealer to run some tests with a special scanner.
Jun 24, 2016 | 2010 Dodge Challenger
Interior lights, gauges, door locks etc not working.
What kind of manual do you have ? Haynes or chilton manual ? these are no good , they don't show everything ! If you want one that shows everything . Go to ALLDATAdiy com Leading Source of Factory Automotive Repair Information
Checking power an grounds to the affected circuits would be the place to start . Using a wiring diagram to locate points in the circuit to test using a DVOM - digital volt ohm meter .
Looking at a wiring diagram i see that the lights an the power door locks master switch share a common ground - G- 200 could be a loose connection . Look at alldata would show location of this ground point as well as any other ground on the vehicle . Plus gives description of how all the systems on the vehicle work .
Do you know what voltage drope testing is ? Do you how to do automotive electrical testing ?
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
May 19, 2017 | 1995 Ford Crown Victoria
Receiver lost signal, cannot aquair
It sounds like the dish may be mis-pointed since it's not recognizing all the satellites. The next step for this would be to send a technician out to get everything fixed.
If you would like any assistance setting up a technician, just send me an email at thomas.faust@dish.com and I would be happy to help.
Tommy Faust
DISH Social Media Representative
Jul 01, 2012 | DISH Network DVR-625 DTV Receiver /...
Jbl jrx 100 popping
Check all electrolytic capacitors on the amp circuit board.
Jun 05, 2012 | JBL JRX-118SP Subwoofer
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
I have 2 x jbl jrx 115 and 2 x jbl jrx 118s, we set up a power amp to desk and the 118s, into the left hand speakon connection, using a speakon to speakon cable, from the 118s a speakon cable is run out...
In spite of your description it is not quite clear of the connections... In general you should limit the number of speakers connected to an amp output to a maximum of two. I am not sure if you might have more than that in your daisy chain. Let's go over another important thing: are ALL of the amps and the mixer (desk?) powered from the SAME receptacle or power conditioning module? If not, make it so even if you have to run extension cords. The ground bounce of building power at venues can destroy your equipment. The brand/model of the amp(s) and the mixer would be useful to analyzing the problem. It is unlikely the failing battery in a guitar would kill one side of the PA. If the amp is overloaded, the thermal cutout may be disabling part of the amp and the system. Also please verify the RMS capability of your amp. You want the power of the amp to NOT exceed the rating of the speakers USE RMS VALUES... not the fakey "program" or "peak" ratings... those are just advertising gimmiks to show my numbers are bigger than yours... we know that game...
Sep 18, 2011 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
Car wont start or if started runs poorly 98 ford taurus 3.0
check the fuel pressure or sounds like mass airflow metter itself
Feb 28, 2009 | 1998 Ford Taurus
1990 Dodge Ram Wiper not working
You did everything else. You have voltage going to motor,so I would say that was it.
Jan 27, 2009 | 1990 Dodge Ram
No sound
I would try it without the slot for the additional amp. However, there is a chance that it is fried. When its powering up I would check the voltages with a multimeter to make sure everything there is in order.
Jul 02, 2006 | Infinity 7540A Car Audio Amplifier
JBL JRX118SP Microphone Logo
138 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
