Question about Toshiba Satellite Notebook l505dls5005
Laptop satellite 505D-S5983 numbers pad on the right of keyboard do not work, numbers at the top work just fine. I tried the num lock but still does not work. Any advice would be helpful. Thanks
  • glen48nj May 10, 2010
    thanks for the answer. Iam not sure how to enable it in the bios. but i'll try to do some research on how to do that.
Hi Guys,
I had this issue and after checking the BIOS and various other tests in safe mode, solved it by following these simple steps.
Go to "Ease of Access centre"
Choose "Make the mouse easier to use"
Uncheck "Turn on mouse keys"
Choose Apply and ok.
Worked for me, might work for you.
Cheers
Denv
Posted on Nov 16, 2012
  • 68 Answers
Maybe it is disabled in the bios , try to enable it and it will work
Posted on May 09, 2010
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Numeric key pad on right wont work on aspire 7741 notebook
Maybe you need to press the Num lk (number lock) key at the top of the keyboard, then Press and Hold the FN function key at the lower left portion of the keyboard then hit the number key you want..
May 06, 2012 | Acer Aspire 7741z
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
WHAT IS THE ICON ON TOP TO THE LEFT OF THE CAPS LOCK ICON? HOW DO YOU TURN IT OFF?
This is either the Num Lock or the Scroll Lock. To turn off the Num Lock, look at the top left of your number pad on the right side of the keyboard, and press the Num Lock key. To turn off the Scroll Lock, press that key in the middle of the top row of 3 keys above your arrow keys.
Feb 27, 2011 | Dell 0Y3740 Keyboard
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Hi, my toshiba satellite L505 num pad is not working, even the num lock is on when i press the numbers it only beeps please give me some solution
is the laptop booting fine if yes ,then it can be the problem with the keyboard try to remove the keyboard and clean it then fix it but do this when the laptop is off also remove the battery while doing it if the problem persist the contact service centre
Dec 07, 2010 | Toshiba Satellite A135 Notebook
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Asus a6 laptop keyboard problem
your number lock is on. Since there is not enough room on a laptop for the right hand number pad you find on many desktop keyboards, they incorporate it into the text keyboard. Generally there is a key in the upper right side to toggle the number lock, also if you enter the bios mode and check that number lock is not enabled on boot.
Feb 03, 2008 | ASUS A6U Notebook
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
Toshiba Satellite Notebook l505dls5005 Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
