Question about Sirius STILETTO 100 MP3 Player
Bad Wheel The nav wheel on my Stiletto 100 has slowly been losing functionality and is now dead. Can I get a replacement one somewhere? If not any suggestions on who can reapair it for me? Thanks, Brian
  • 2 more comments
  • puppotta Mar 29, 2008
    my wheel is going bad to and my battery pops off the back as well.
  • rwcj63 May 09, 2008
    i have the exact problem. can anyone repair?
  • Anonymous Jun 10, 2008
    We bought the Stiletto 100 for a Christmas present for my step-son and he is having the same problem with the dial (wheel) also. Can not get it to move up to select programs.
  • llsaari Nov 21, 2008
    Like the other complaints, my nav wheel no longer works. Actually, it works only in one direction but this is not very useful.
There is a guy in Maine who says he can fix it. It is available through ebay. Put in Stiletto 100 in the search field and he comes up under "Broken Wheel Repair Service". Cost is $24.95. I'm going to give it a try.
Posted on Sep 27, 2009
  • johnt61 Oct 02, 2009
    I sent my unit to Richard in Maine on Monday (overnight) and got it back on Friday. It works perfectly. Go to ebay and you will find him
  • 8,596 Answers
There are no repair services - player must be replaced.
Posted on Jun 10, 2008
Anti-lock function on brakes is triggered by applying brakes while steering wheel is turned hard over
Sounds like you are losing wheel speed signal when under hard turns. This is commonly caused by the harness at or near the wheel speed sensor has a bad connection of there may be a break in the wiring that intermittently loses signal to the ABS module and causes the anti-lock function to happen, (loss of wheel speed is like wheel skid as far as the ABS module is concerned) It is usually necessary to have a scan tool to monitor the data and read codes on the ABS system. You may have to take vehicle to shop that is capable of diagnosing the problem.
Oct 13, 2015 | 2003 GMC Sierra 1500
2005 caddy sts .want to change radio to big screen nav ,bluetooth .will all buttons still work on wheel and mirror
You will probably lose some functionality with an aftermarket radio. There are interface wiring adapters that will allow installation without needing to cut the vehicle's wires (highly recommended) and restore some functions (such as chime notifications) but in all likelihood - not everything. Crutchfield has some good info on what fits / works with different vehicles.
Check them out here:
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Feb 03, 2015 | Cars & Trucks
Replaced lamp on samsung dlp - will not turn on - color wheel is intact but will not move - it sounds like TV is trying to start up but after three tries all three LEDs turn on - is this possibly a bad...
No,the tv colors wheel it is also dead or lose connections somewhere,because there no movement at all and all the LEDS indication lights are flashing and not giving power voltage to the tv colors wheel part at all.
Jun 22, 2011 | Samsung DLP HL-P5663W 56" TV
My Stiletto 2 works fine in the car and in the home dock, but it will not read my battery. I have changed batteries out with another Stiletto 2, and the batteries show 100% charged in the other Stiletto,...
You may want to try to run a device recovery. Sometimes when a battery is drained, the Stiletto only remembers the status of the last battery as it ran completely out. A device recovery would help it reinitialize and recognize a new battery. Instructions and links for device recovery can be found here: http://www.tss-radio.com/links
Jun 13, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
I have a rubbling noise when the TV is on. The picutre and the the souind is clear although you hear this loud rubbling (bad bearing noise) fromtheback of the TV. When you turn the TV of, the noise is...
This DLP tv have a colors wheel.No,the colors wheel is dying,just not dead yet.It spinning off of it motor axis,when it total dead it will have black&white pics,very loud squiling motor noises.Ur tv need a new colors wheel.Call the tv repair tech for this job,require take out many machanicals parts,before even can take the colors wheel to replaced.Never done this before,don't atemp to replaced the colors wheels ur self.
Jun 14, 2010 | Samsung DLP HL-P5663W 56" TV
My left front tire makes a rubbing or grinding noise when I drive. When I turn the wheel either way it also rumbles and bangs. What is causing this?
You could have a bad wheel bearing or a bad CV joint. Inspect your CV joint by turning the wheel all the way to the left and inspect the rubber boot for any signs of damage and see if there is any play by grabbing the CV joint and try to move it.
The other way to check is to drive the van slowly in an empty parking lot turning the wheel to one side and then the other. Listen for any abnormal noise and see if you can feel anything lose through you steering wheel.
If there is any signs of damage to the CV joint like oil leaking or movement. Replace the CV joint as soon as possible, and try not to drive the van till you have the CV joint replaced or the wheel bearing. Total CV joint failure will cause you to have the van towed to have it replaced. Try to drive it to the Garage to save you the tow cost.
Thank you for using fixya and be safe.
May 11, 2010 | 1998 Ford Windstar
Sirius stiletto 100 LCD screen partially broken
I do this repair for a broken LCD on the S50's. I am on Ebay and my user name is rarey57siriusXM. Look me up I also do LCD and scroll wheel repairs for the Stiletto 10 and 100's. Cost of this repair service is $24.95 and that includes free priority mail shipping back to you on all these different repairs. Thanks
http://myworld.ebay.com/rarey57siriusxm
Oct 30, 2009 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Scroll wheel goes crazy/ not responsive
Oct 06, 2009 | Sirius STILETTO 100 MP3 Player
The scroll wheel does not respond
Go to ebay and look under Stiletto Wheel. A guy in Maine will fix it for $24.95. I overnighted it to him on Monday and got it back on Friday. It works perfectly, well worth it.
Sep 23, 2009 | Sirius STILETTO 100 MP3 Player
2001 olds ABS and traction control sensor issue
An ABS sensor DOES affect the traction control system. Traction control uses these sensors to determine if a wheel is losing traction. A bad sensor will cause both the ABS and TRACTION lights to come on.
The CHECK ENGINE light however is going to be a seperate problem.
Jun 08, 2008 | 1999 Mazda Pickup
Sirius STILETTO 100 MP3 Player Logo
398 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
