Question about Refrigerators
My Frig.. Started making a rattling noise ever once in a while.. but worked fine.. But now since the weather started getting warmer it has stoped cooling almost all together .. but wen the nights are cool and i leave the back door open it starts to cool/make ice again ?? any help out there,, thanks in advance.. it's a older kenmore with top freezer and ice maker.. Oh yes,, it dosent make the rattling noise anymore eathier.. David
  • 316 Answers
Check the fan by the compressor, likely not running
Posted on May 09, 2010
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
After sitting for a week or so during extremely cold weather, my 1995 Nissan Altima was hard to start. When I did get it started, it was making a loud rattling sound. The noise doesn't go away, but i
rattling sounds like a busted rocker and the valves are loose. when it doesn't start on the first try or so, that sounds like a head gasket. they tend to start better when its hot because it swells some and improves compression. I had a dodge do that but it will only get worse if that's what it is. If you don't get it fixed now you'll eventually warp the heads and be looking at a head job or worse a new car cause its terribly expensive to fix the longer it goes
Feb 20, 2014 | 1995 Nissan Altima
2008 Jeep Patriot. Engine makes rattling/grinding noise near right wheel well when making a right turn. This problem started when the weather hit about 20 degrees.
sounds like a wheel bearing,one piece hub and bearing,not a hard fix ,bearing is like 100 bucks tho. Don't let it get worse,the wheel could lock up
Dec 10, 2013 | Cars & Trucks
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
My Audi A4 2009 makes a rattling noise on cold starts which resolves in less than 30 seconds. Dealer says its an air pump. This doesn't seem correct. The noise comes from the front of the care. Does not...
READ THIS (happy ending so far...):
audi a4 2L turbo quattro, manual transmission with 98,000 KM. Perfect conditions, no oil leaks whatsoever.
Left the car off for two weeks in very cold weather (-10C down to -25C). When I restarted, it started immediately but with heavy rattling noise due to camshaft adjuster not getting enough oil pressure. After 3 minutes of warming up (outside temp.: -12C) at very low rpm (below 2,000rpm), I start moving the car. Still hearing heavy rattle noise. As soon as I pass 2,000 rpm, I get a scary red warning, low oil pressure. Turn off the engine immediately. In 1 minute, I re-start the car and the engine lights check ok, so I drive in first gear super slow (1,200rpm) hearing the same rattling noise. After another minute, finally the noise all the sudden disappears and the car starts running just fine.
Called Audi dealer and they told me that in extreme weather conditions, I should warm the engine for 10-15 minutes if necessary before start moving.
Take away: luckily, I didn't screw up the engine since I was using it at extremely low rpm (easy to do with clutch and manual transmission) until the oil reached full pressure. I am pretty sure now that the problem was leaving the car off for such a long time in freezing weather. All the oil flows back to the bottom, and when I restarted it, the cold oil with high viscosity took a long time to reach all the parts of the engine, specially the camshaft adjusters that are actuated by using oil pressure. Next day, the car started at -9C perfectly without making any noise (as usual). Basically, the longer you leave your audi in cold weather, the longer you might hear the rattling noise until the oil reach full pressure inside the engine. My car took 6 minutes to fix it after couple of weeks in cold weather. This makes sense to me; in fact, in the past I only heard the rattling noise after leaving the car off for a couple of days in the winter.
So far, this has had an happy ending....
Dec 19, 2010 | 2009 Audi A4
Frezzer kid off cold frig barly and making huming noise
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 14, 2010 | Jenn-Air JCD2389G Side by Side...
Frig not getting cold enough. Freezer section
heatman101
Jul 19, 2010 | Kenmore 21 cu. ft. Top Freezer...
Major vibration or bucking sensation when slowing to a stop. Shifting into neutral stops it. Started in fall but disappeared in colder winter months, now is starting again as weather gets warmer. Any...
I have same problem with my 2005 with 65,000 miles---think it is down shift between 2nd & 1st gear making noise. I read on ford 500 forum
that the dealership reprogrammed the transmission---but not sure how this works.
I welcome any advise.
Apr 09, 2010 | 2005 Mercury Montego
Our Beko Fridge Freezer has started to make a rattling noise. When it is turned off it stops and starts again once turned on again. Any thing we can do to fix it?
When it is off, gently shake the frig to see if the rattle is something in the frig hitting togrther. If that is not it it could be the compressor hitting the case inside due to a broken spring on the motor. The only repair for this is replace the compressor. In which case you let it run like that till it quits completely. That can be a very long time. Eric
Aug 10, 2009 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
