Hi i have an acer aspire 5520 and was looking to clean my c drive. but i didnt get a cd with the the laptop package when it arrived. help me please
    Sergeant:
  • 349 Answers
When you first received the laptop and turned it on ,it would have asked you to make a recovery disc,
if you did ,(and if i understand you correctly ,you want to format the hard drive),
put it in the cd drive and boot up to recover your hard drive,
or when you boot the laptop up, it will tell you what button to push (sometimes F11) to go to the recovery partition, and restore it back to the factory settings,read the manual.
you may need to reboot a number of times to catch what it says if you don't have the manual,
then you will be asked if you want a destructive recovery (lose all date) or not ,this depends why you want to clean the hard drive.
a none destructive will leave your programs on the hard drive and restore only the operating system & drivers.
good luck
Terry
Posted on Mar 28, 2008
SOURCE:
My Acer Aspire 5520 doesn't find his Dvd/Cd rom anymore I even tried to delet the upper and lower filters in the regedit resetet my bios and reinstaled Windows Vista still it not working
Hi
maybe you could get the driver from here
www.acer.cam
use scroll down boxes to find your model and operating system
then scroll down and look for the cd/dvd driver if available
good luck
Apr 24, 2011 | Acer Aspire 5520-5908 Notebook
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
Acer aspire 5520 ask for bluetooth peripheral drivers please help
Hi here you've got link to drivers for your laptop just choos witch You want and get it it it help please rate it. Regards http://support.acer-euro.com/drivers/notebook/as_5520.html
Oct 29, 2010 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 cd rom drive is missing
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 05, 2009 | Acer (99.B0311.002) Internal 50x CD-ROM...
Acer Aspire 5520 Vista Cannot Read Disc no matter what
You probably need to swap it out, lasers and spindle motors often go bad.
Get a new drive off ebay (you can even upgrade to lightscribe for like 10$ more at this point): http://shop.ebay.com/items/?_nkw=Acer+Aspire+5520+cd+drive
Looks like you need to take the keyboard off and unscrew the screw holding the cd-drive in.
Mar 25, 2009 | Acer Aspire 5520-5156 Laptop
Wont find cd drive acer aspire 5520
hi .. sir
go and try to open in safe mode .
restart >press F8.
see whether it work's..if not go to the bios setup and see the configuration and sellect . restart > delete . (for bios setup..).
replay me if any problem.. thank u sie. don't forget to fix.
Sep 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
ACER ASPIRE 5520 CD DRIVE NOT WORKING
hi
if you bought it from new it's still under acer's warranty call them for repair or replacement, if not do a system recovery i think you press ALT + F10 as soon as you switch the laptop on restore it to factory settings if that doesn't work your drive is faulty and will need replacing.
May 03, 2008 | Computers & Internet
If it's brand new and giving you problems already I would take it back.
Unleash Your Computers True Potential!
Apr 19, 2008 | Computers & Internet
How to get Service manual for 5520
I have the 5000 series service manuals, please email me at
[email protected] and I will send them to you.
Feb 09, 2008 | Acer TravelMate 2300 Notebook
Open Questions:
Computers & Internet Logo
73 people viewed this question
Ekse
Alun Cox
