Question about Samsung HL-P6163W 61" TV
Samsung dlp color issue
I just replaced the color wheel on my 2005 hl-p6163w television. Everything seems to work fine, but now the color is real bad. People are real blue and when the screen is dark its loaded with green. Even the blue menu is a rusty color.. any advise. Mark
  • saleedavis Oct 03, 2008
    Replaced the color wheel, had the color problem, pulled the jumper wire, tv would not come on, indicating "Lamp, standby." Replaced the jumper wire, tv came on but with same color problem.
On the front of the DMD Board to the right of the fan is a sticker that says CN801. There is a small jumper there. Remove this after replacing the color wheel and it will fix the color issues.
Posted on Aug 18, 2008
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Posted on Jul 20, 2008
SOURCE:
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
CAN THE COLOR WHEEL PREVENT YOUR TV FROM POWERING ON? I HAVE A SAMSUNG DLP TV.
Yes. Of course. If the speed of rotation of color wheel to a projection TV or projector vary, it can obstruct proper working of the set. If you want more details about how can replace a color wheel to a DLP projection television, visit this site 'Electro-help'. Type in "electronicshelponline.blogspot" to your browsers' search box, and click search. Pull up older posts there. All details are there with illustrations. It is a blogspot site in English Language.
Jun 27, 2012 | Samsung HL-P6163W 61" TV
I have a HL-P6163W, hooked to dish network hd
Fire the TV Tech! Your problem is the adjustment to the color wheel timing. To correct this: With TV OFF -> on remote, press MUTE, 1, 8, 2, POWER. The TV will come up in service mode: ( Left / Right arrow keys for item selection, Up / Down to change values, Menu to return to previous menu, Power to exit Service Mode)
Enter the submenu of item 1. DDP1011. Now, adjust item 4. INDEX DELAY to correct the "clay facing" problem you are having . Default value is 47.
You should have a "problem" image paused to check you work if possible. I hope this was of some assistance, best wishes.
Apr 12, 2010 | Samsung HL-P6163W 61" TV
Samsung 61' DLP Color problem.
If you are using Component inputs, check to make sure that the Blue Video Cable has not backed out of its connecting jack at either end or the cable it's self being bad. If you are using HDMI I would suspect that the Digital Board being bad. It would be odd for the Color Wheel to cause the problem but cannot eliminate it as a cause. The Lamp would cause the picture to be darker but not cause a color to drop out.
I would call a professional to trouble shoot it unless you have the knowledge and the tools to do so.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung HL-P6163W 61" TV
Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Jun 25, 2009 | Samsung HL-P6163W 61" TV
I need instructions on installing a color wheel
i found a step by step video on you tube it was great
May 05, 2009 | Samsung HL-P6163W 61" TV
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
Remote stopped working after color wheel replaced
See http://www.consumermeet.com/entry/samsung-remote-wire.html , that seems to address the same problem.
Aug 26, 2008 | Samsung DLP HL-P5663W 56" TV
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HL-P6163W 61" TV Logo
398 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
