Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Clean light stays on but the cycle does not start
Hot water is on .I think that maybe it could be that the supply is pluged .the clean lite is throwing me off.should i take apart the supply on the dish washer?
    President:
  • 949 Answers
Is the clean light on solid or blinking?
Posted on May 09, 2010
  • Philip May 09, 2010
    The clean light will flash if the machine does not sense a rise in water temperature. If the water supply is not sufficient then the clean light will blink.
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Sep 20, 2012 | Water Heaters
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Cold water cycle doesnt work, no cold water at all, just hot
    Could be the cold water solenoid is stuck or broken, maybe a wire has broken or terminal worked loose.
    You need to take a look inside and check the wiring, check the supply to the solenoid, etc. If the supply is good the solenoid is probably faulty. If there is no supply it is possibly the board or the controller.
    Jun 18, 2017 | Maytag Legacy Series Top Load Washer
    Kenmore 665. dishwasher blinking "clean" light
    kenmore lite blinks on quick rinse, seems to be stuck on that.
    Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
    ASKO 1595
    yes have you tried what i suggested yet
    Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
    Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
    223 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
