Question about Insignia IS-PDVD10 Portable DVD Player
Freezing video The player will freeze on some dvd's and can't play any recorded dvd's at all. Does anyone knoe of a fix or firmware upgrade that may work.
    Novelist:
  • 170 Answers
Different discs are read with different focus ranges. Production pressed DVDs are different in thickness that recordable DVDs and CDs are also different than the afore mentioned items. Your optical transport could be out of alignment, but check to see if CDs will play first. If CDs and Production DVDs will play, it is possible that you have a dirty lens or there is something interfering with the laser (i.e. dirt).
Here are a couple of solutions:
If this unit had worked in the past and has started acting up without being droped, jarred, banged, or slammed around, then it may very well be as easy as dirty optics. Get a lens cleaner kit or a Q-tip with a little glass cleaner and clean off the lens of the optical transport.
If this does not work:
You will need to see what the optical transport is doing. The door needs to be opened and the switch that tells the player the door is closed needs to be tripped (usually with a paper-clip or small tool). Watch the optical transport to make sure it moves back and forth, up and down BUT DO NOT LOOK INTO THE LENS DIRECTLY as this can cause retinal damage. If it does all these things, then the motors are working properly and the issue is either in the optical alignment or the decoder chip.
If it's the optical alignment, you might be able to open the player and start changing the height of the drive placement so the laser focuses more accurately on the disc. This will require a disc with an opaque or printed side to stay in the drive while you calibrate. You can then safely look at the disc and see the red dot of the laser to determine the size of the dot. The smaller the size, the more in focus the laser is. This calibration must be done for the entire length of the oprical transport track. there are two screws that change this on either end and both muse be checked and calibrated. The optical transport has some focus adjustment capability (hence the up and down motion of the optics), but if the transport is beyond the limited capabilities of the auto focus, it needs to be brought back to correct.
Posted on May 12, 2008
SOURCE:
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 19, 2009 | Sony BDP-S350 Blu-Ray Player
Freezing dvd recorder
Try to return it as defective
Apr 21, 2017 | Televison & Video
Recorded DVD disc freezes up on a different DVD player
hey ,
recommendation, the disc may have an internal scratch. (meaning when its played there might be a bump or something on it unseen by the human eye)
or you can stop being cheap. and get a new one
Jan 20, 2009 | Universal Music and Video Distribution...
Picture/Sound freezes
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Aug 13, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Samsung dvd r-120 recorder
First make sure there is not a DVD or CD in the tray. It must be empty. Turn the unit off, then on. Then press the "play/pause" and "stop" buttons. This will reset your DVD player. This worked for me. Unfortuantely the DVD player has always had issues with DVD's that play over 90 minutes. At this point it freezes. I have updated the firmware. It seemed to freeze earlier prior to the update (say around 45-60min). It came free with my TV, which after a year was replaced as it required a $2k repair.
Jun 03, 2008 | Samsung DVDR120 DVD Recorder
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
Dec 29, 2007 | Panasonic DMR-E50 DVD Recorder
Picture freezes
Is this problem happening when playing back from DVD, VCR or internal disk?
Sep 30, 2007 | GoVideo DVR5100 DVD Player / VCR Combo
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
Firmware for conia 160gb dvd recorder
sir try this link! http://www.dtvforum.info/index.php?showtopic=32172&pid=632554&st=40&#entry632554
Apr 06, 2007 | Conia DVD8500 DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
93 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
