Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 111h wont turn over
Just replaced all the fuel lines and the fuel filter but it wasn't running before i did that i just replaced them all because i was meaning to anyways. the inlet(elbow fitting) from the fuel pump seems to be lose when i jiggle it a little fuel comes out the fuel pump seems to be working when i run it with out being connected it drops a few drops i don't know how much its supposed to flow so im not actually sure if that's how it should be. it did sit awhile so i was told to blow into the gas tank to push sum gas up and wet everything again i actually did have it running to day for a bout 5 min i made a lap around my back yard then i turned it off to open the gate to the front yard and i couldn't get it going again so im back to the beginning.
  • John Deere Master
  • 7,515 Answers
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
Posted on Apr 22, 2017
  • 77 Answers
SOURCE: I have a John Deere/Scotts/Home Depot 20 hp
The easiest way is to not remove the tank. Buy a can of chem tool the liquid,not spray.Drain gas out of tank,pour can in tank,let sit for 15minutes,then drain,should clean it out good.
Posted on Aug 10, 2009
nova2nv
  • 197 Answers
SOURCE: Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Posted on Nov 14, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
co7196
  • 3433 Answers
SOURCE: 2yr old x300 john deere riding lawn mower wont turn over
Chk the fuel by draing the carb bowl and the black thing may bea ck valve. Remove it and see what happens. Oh! drain the old fuel entirely and fill with fresh fuel. Good Luck
Posted on May 28, 2010
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
Search Fixya...john deere 1742 stalls
If your tank had black stuff in bottom check fitting for line going in fuel tank take piece of fuel line look if inside is swelling close and soft ethanol fuel is ******* rubber replace lines don't cost much
Jul 03, 2013 | Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
John deere 2210 keeps stalling/
If you have already replaced the fuel filter then you need to check the fuel tank to see if it has debris in it that is restricting the fuel to the filter.If you are not having a fuel delivery problem then you may need to replace the rubber fuel lines,they may be sucking in air,you will not see this as a fuel leak because of the vacuum on the lines but air in the return lines will cause problems and also air in the delivery side of the fuel will also give you grief.
Jul 27, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I try to start a 7420 deere tractor and she wont go. i
You need to check your fuel lines from the tank to the filter head and the lines from the filter to the fuel cooler in front of the radiator.If all are goo and the fuel pump is running then you may need a fuel filter.If the fuel is not an issue then you need to call the nearest j.d dealership and give them the stored codes[the operators manual will tell you how to retrieve them].If any lines are wet with fuel then they need to be replaced,a long running problem with Deere.
Jan 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
100 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
