Question about Frigidaire FRS26R4A Side by Side Refrigerator
How to fix water dispencer leaks
Water dispencer
  • 316 Answers
You probably have a bad water valve
Posted on May 09, 2010
The problem i'm having with my washer is that it's leaking water underneath the detergent dispencer. I had the same problem a while ago and a tech fixed it he found a sock in some were in the dispencer but...
Remove the door bellow, small spring around the outside of the rubber boot. Peel the upper LH corner of the boot back and you will have access to the dispenser outlet.
Kelly
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
I have a 25 year washing machine that is leaking (not much) from underneath. all hoses are fine, drain too. It's the first problem i have had with it. Can this be fixed?
Check door seal, also if you remove top and put onto fill you can then see if the soap dispencer is leaking also pipe from soap dispencer to drum. Also it could be the pump leaking, this was common on some old machines.
Feb 12, 2010 | Washing Machines
The ice dispencer would produce ice
Dear Adriana, I have the exact problem. I have yet to find a clear solution to this problem. The temp in the freeze seems to oscillate too much, and the leaking water led to a damaged light in mine.
Have you discovered a solution? It was recommended by a repairman to replace the controller board for the unit. I have yet to implement this approach. Wondering what others have discovered.
Marco
Dec 06, 2009 | GE PSC25MSS Stainless Steel Side by Side...
MY WATER IS ALWAYS DRIPPING..HOW CAN I FIX IT?HELP
you may want to check your water presuure if pressure is to low the valve in the back of the fride is not closing properly or the valve is defective to check for this you need to remove the electric solenoid behind the fride leave the water line installed disconect the output tubingif it drips replace the solenoid valve gilles_dumais@hotmail.com
Mar 15, 2009 | Whirlpool ED2FHSS Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool side by side water dispencer
Sounds like some switch wires at the water valve.
Should be color coded.
May 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
