Question about Samsung Audio Players & Recorders
Problem with ejecting the DVD from Samsung HT-BD8200
I'm not able to eject the DVD from my Samsung HT-BD8200. It says "loading" all the time and pressing the eject button doesn't work. Switching off is also not effective. Earlier there were some problems with loading some DVDs. It was interesting because the problem was with the very same DVDs that were already watched with this Samsung.
Thank you very much.
Best regards.
Marcin
bluenadas
  • 203 Answers
SOURCE: how do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
Posted on Jun 15, 2007
SOURCE: DVD load / eject problem
This is a solution to all those who have either a DVD which does not load and which cannot be ejected and also to those who have the system stuck in MP3 mode. The solution is the same for both problems. Unfortunately due to the design of the HTS6510 it’s not a simple job but if you are methodical and take your time then most people should be able to do it.
 I personally think the problem stems from dust building up on the laser. I noticed that the extraction fan at the back of the unit draws air, partly, in from the front slot and over the DVD and (Sony) laser.
Anyway I’ll talk you through what I did but please be aware that this is not a screw by screw, connector by connector account.
You’ll need a small torx screwdriver (the unit is put together almost exclusively with a single torx screw size),  a very small Phillips screwdriver and a pair of snipe nosed pliers. Also a couple of small bowls to hold the screws in will be a good idea.
Firstly make sure the unit is disconnected from the mains. Then begin by undoing  the four torx screws at the back of the unit which are holding the cover on. Then remove the silver plastic side sections by sliding them towards the back of the unit. Under these you’ll see two more torx screws to be removed on each side. Remove these and you can then remove the top cover.
Have a look at the first attached picture. You should see the same thing with the lid off the box. I’ve labelled all of the assemblies up. There are four circuit boards which are arranged two on the top and two underneath these. You will be removing the top two (Audio amplifier board and the power supply board).
The aim of the game is to move the front section (the bit with all the control buttons on) away from the main section so that you can get access the to the DVD housing (this is the player unit where your DVD is housed). The front section is attached to the main section by four plastic clips (the plastic barb to metal slot type). Two are accessed from the base of the unit and more on each side. Don’t unclip these yet because the circuit boards are attached by ribbon cables which attach to the front of the unit . It is these ribbon cables which must be disconnected before the front can be unclipped and access can be got to the DVD unit. There are also a couple of bonding leads which attach the front of the unit to the ain chassis. These have small spade (push on) connectors and are very simple to remove.
You don’t need to disconnect all of the ribbon cables – just enough for you to be able to swing the front of the player out of the way.  Make sure you mark any connectors which you disconnect in some way so you remember where they connect to when you re-assemble the unit. I used a permanent marker to put a series of dots on the ribbon end of the connector and board end of the connector. (i.e. one dot on each denotes a pair, the next pair has two dots etc etc.)
Some of the leads which you will need to disconnect are attached to the two processor  boards which sit below the two uppermost circuit boards. Gain access to these by removing the four screws (one on each corner) holding the power supply board onto its mounting (there is also a nylon support in the middle of the board – squeeze it with a small pair of pliers to release the board).
Next remove the black plastic insulator sheet below the board. With this board removed, the metal shelf which the Audio amplifier board is attached to can now be removed. Note that some of the screws on the external back of the unit will also need to be removed before you can do this. You don’t need to take the audio amplifier board off the shelf – just remove the shelf and audio  amplifier board together.
You should now have an assembly which looks like my second picture. As with the top two boards unplug the connectors on the boards to allow the front section of the dvd player to be moved away from the main part of the system. Again don’t forget to mark the connectors so you know how to re-connect them.
If you have got this far you are doing very well!  I then undid the four screws holding the dvd housing and unshipped the entire housing, but with hindsight this wasn’t necessary. There are four Phillips screws holding the top cover of the DVD housing on. Remove these with your Phillips screwdriver and lift off the lid.
You can now remove the DVD / CD. At the same time carefully remove any dust which has accumulated in the DVD housing. Take care not to damage the delicate lens or its assembly. I used a dry cotton bud but a blast of dry air or a lens cleaning brush would be an even better choice.
Once the dust is removed refit the cover the DVD housing and assembly is basically a reversal of the dismantling. Once its all back together switch on and they system will be back to normal. If it doesn’t switch on – open it up and recheck your connectors – most likely one of them isn’t properly engaged.
Posted on Nov 02, 2008
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
SOURCE: Disk stuck in my Blue Ray
Hi!
I had the same problem, and I solved it by shutting down the unit and then disconnected the power supply for some sec. When re-connecting the power supply and pushing the start button the DVD was ejected when pushed the eject button.
Egil
Posted on Mar 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: my ht-x200 will no longer read any dvds. The
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Feb 05, 2011
Samsung blu ray will only regular dvds
Are the discs commercial or made on another computer?
Jan 19, 2014 | Samsung Ht-bd8200 Home Theater System - Bd...
Reciever stuck on load won't go into any menus or play DVDs will eject DVD and load and spin but not play
you have possibly have a lens problem..
But it is expensive so its better if you buy a new one
Nov 08, 2012 | Samsung Ht-bd3252t/xaa Blu-ray Home...
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
My samsung ht c350 wont eject, it says lock when i try to eject it
Found out how to solve this problem, as it has put a child lock on the device, try holding the Stop button on the remote for five seconds. This resets the device, then turn it back on and it will go through inital setup and then try oepning the tray.
Andy
Jan 14, 2011 | Samsung DVD-C350 DVD Player
SAMSUNG HT-BD8200 - No disk inserted and stucks saying "loading"
Mine did the exact same thing today. If you figure it out please let me know. drsweet2006@gmail.com
Jan 10, 2010 | Samsung HT-X810T Theater System
I currently have a DVD in and it won't eject. I have a Samsung HT-Q100 System
Turn off the DVD player completely. You MAY have to turn off the tv too. Let sit until you count to fifteen! Turn back on, tv first, then DVD player. You should be able to eject the disc then.
Jan 01, 2010 | Samsung HT-Q100 System
Samsung blu-ray player won't eject, tried turning off power strip and waiting 10minutes then trying again, still didn't work
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Hi!
Egil
Dec 30, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT-DB120 DVD tray
I assume it DID work at one time. You need to take it apart and see how the tray is driven... belt or gear. If belt driven you could replace the belt.
Geno
Mar 04, 2008 | Samsung HT-DB120 System
DVD will not eject the tray
Open up the unit find the load and unload motor on the DVD carriage and turn it manually and this should eject the tray. You may even have to unscrew the carriage to get to the bottom of it to access the load and unload motor.
Jun 21, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
487 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
