Question about Whirlpool Duet GHW9150P Front Load Washer
DETERGENT I NEED TO FIND OUT WHERE THE POWDER SHOULD GO IN THE WASHER. WE JUST RECENTLY PURCHASED IT AND WAS TOLD THAT YOU CAN ONLY USE LIQUID IN THEM, BUT I HAVE FOUND A POWDER FOR HE WASHERS THAT I WANT TO USE. THANK YOU FOR YOUR HELP.
  • Whirlpool Master
  • 8,220 Answers
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount. Nearly all brands of "HE" detergent have incorrect instructions. The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
These washers MUST have the right amount of the right stuff or they simply will give you lots of grief. The program can sense suds. It cannot pronounce your wash clean if it thinks their are suds. So it try's to fix the problem and ends up overworking itself.
Posted on May 09, 2010
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
Gltf1670as1can you use powder detergent in ?
Good Morning Friend,
I understand that you want to know if you can use powder detergent in your Frigidaire washer, model# GLTF1670AS1. Below are the advised steps for the detergent dispenser of your washer.
• Add measured detergent to the detergent compartment of the dispenser drawer.
• Detergent is flushed from the dispenser at the beginning of the cycle. Either powdered or liquid detergent can be used. Note: Liquid detergent will drain into the washer drum as it is added.
• Low sudsing detergent is recommended for this washer. Use the manufacturer's recommended amount.
• If low sudsing detergent is not available, a reduced amount of regular detergent may be used. Because
reducing the amount of detergent may reduce cleaning, it is important to pretreat stains, sort carefully by color and soil level, and avoid overloading.
• Detergent usage may need to be adjusted for water temperature, water hardness, size and soil level of the load.
• For best results, avoid oversudsing.
Hope this is helpful.
-Best Regards-
WP
Jun 05, 2014 | Frigidaire Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Detergent will not dispense
generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Mar 07, 2009 | GE WSXH208A Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Powder vs. liquid laundry detergent
I was searching the net looking for the same answer - have just bought an LG front loader but wasn't certain I should be using liquid detergent - my manual refers to powder without telling you specifically to use it only. Look at the answers to the question after yours on the Fixya website "LG washer has awful mildew odour" or something similar. Solution 3 by Tresilla convinced me I should use powder! Also, the salesman who sold me the machine recommended powder because, quote, " gentler on clothes and more efficient ..." - he didn't mention the possibility of a later mildew odour which is apparently generic to front loaders!
Feb 08, 2008 | Washing Machines
MALBER WD 1000- CAN I USE LIQUID BLEACH?
Liquid detergent and liquid bleach are best.
Aug 21, 2007 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
