Question about Dryers
How do I get inside a GE dryer (DVLR223)? There is a repetative "thup, thup, thup" sound when it runs. The top on my previous Kenmore dryer had clips that helt it to the cabinet, and just prying the top up with a putty knife would raise the top, but this unit appears to be more stuborn, like it is screwed down. Any ideas?
    Scholar:
  • 178 Answers
On a GE typically, there are 2 screws located in the top of the dryer dorr as you open it. After you remove those screws, the top will pop up just like the kenmore.
Posted on Mar 28, 2008
SOURCE:
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
When i push the start button the dryer work but when release the button stop working. Dryer GE model DVLR223.
Either your belt is broken or the broken belt micro switch has failed.Or something is pinching the tub and stalling the motor so that it won't go into run mode. OR the motor is gone. No way to tell without taking a look see. I have a service pictorial HERE
Was this helpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2010 | GE DVLR223 Dryers
Dryer is over heating and cuts off
This will occur if the running thermostat is stuck closed. This thermostat will be located inside the dryer on the vent duct or blower housing. it must be replaced in order to restore normal functions.
Also, improper ventilation can cause this as well. have the entire vent assembly cleaned asap.
these
Sep 06, 2010 | GE DVLR223 Dryers
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
Dryer no heating how do I get to the fuses and the heating elemet
using a wide flat screw driver pry the top up at the edges betwenn the main top and the front panel. Lay it down on it's back for this. Now look for your door switch wires and undo them. Now look inside the front panel toward the top and remove 2 attaching screws or hex screws. Lift panel at top and remove. Now undo 3 screws in middle of inside drum and pull drum out after un-doing belt. There you should find your heat element and all the thermostats and the thermal fuse should be labeled. If heat element is not broken then chances are your thermal fuse is bad replace it
Feb 28, 2009 | GE DVLR223 Dryers
Non-existent model number
That Sounds More Like A Serial Number. Can you Maybe Locate A Part Number On The Switch?
Also Why Did You Determine Its The Switch?
Jan 18, 2009 | GE DVLR223 Dryers
GE DVLR223 Not Heating--Is there a reset?
There is no reset. What he did was probably replace the thermal fuse. Why did he not clean it out for ya? Anyway when the thermal fuse goes bad either the whole dryer or the heat won't work. If you can open the dryer up by removing the front panel, you can test your thermal fuse for continuity. If none replace it. While you have the front off undo your belt and remove the 3 screws that secure the rear of the drum (inside drum in middle at back) pull drum out and make sure heat element is not broken. Here is a site for your dryer check it out. www.repairclinic.com/Appliance-Parts?s=t-dvlr223-%3d%3d&z=100 Good Luck
Jan 11, 2009 | GE DVLR223 Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
