Question about Car Audio & Video
Speaker wire colors on 2008 silerado short cab non bose radio.....color of wires goin into door through the door jamb rubber sleeve would be?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
speaker wire colors on 2008 silerado short cab non - modified-life-logo.gif.com its free
Posted on May 10, 2010
Put new speakers in 2002 quad cab. shortly after the two rear speakers stopped working. I ran a wire from one of speaker terminals to a mounting screw. worked again until i closed the back doors.
You are pinching a ground wire. Make sure the wires are not kinked or broken. You should just rewire straight with wires exposed then carefull tuck wires in doors and door jambs.
Apr 02, 2017 | Cars & Trucks
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 01, 2014 | 2005 Hummer H2
I need to find the wiring codes for my radio so i know which color goes to what?
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Green/Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger: Green
Left Front Speaker Positive Wire (+): Black
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Orange
Oct 15, 2012 | 2008 Hyundai Veracruz
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
I have a 2007 clssic body style GMC sierra crew cab and i am having problems with the radiop speakers going in and out also the chime on seat belt warning and overhed dome lights not coming on and coming...
Okay, your truck doesn't have a demon living in it! It does however, have one or two broken wires on the drivers door for sure, and possibly the passenger door as well. Start with the drivers door. You want to carefully inspect each wire in the rubber boot going from the door over to the cab body. If you jiggle the boot you'll see what I mean. The chimes work thru the radio and speakers and that is why both stop working. This may have to do with the dome light as well but, I think it has a seperate wire. This is a very common problem on GMC pick-ups and Medium Duty trucks. You may have to remove the door panel to see what color the speaker wires are in order to trace them. Also, the insulation on the damaged wire may not be broken, just the wire inside. If you can't locate the break, remove both the door panel and the kick panel next to the park brake and run new wires. Starting from about two inches back from the speaker connector, thru the door, thru the boot, and far enough into the kick panel area to give enough wire length to splice them in, 2 or 3 inches back from the main harness connector. There are a lot of wires there so make double sure you match the color before you go snipping wires! The dome light wire is black or black with a white stripe, and the speaker wires may be tan and gray. Make sure to match the speaker polarity with the new wires!
Hope this helps.
Aug 30, 2011 | 2008 GMC Sierra 1500
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Oct 07, 2009 | 1992 Cadillac Eldorado
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Positve and negative speaker wires for 2008 chrysler aspen
Hello latinoheatj5,
According to modified life.com the speaker wire colors for the 2008 Aspen are:
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
You can go to their web site here for other radio wiring color codes.
http://www.modifiedlife.com/2008-chrysler-aspen-car-stereo-wiring-diagram/
Mar 31, 2009 | Alpine Car Audio & Video
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
