Question about Toshiba Satellite Pro 4600 Notebook
The letter A is lit up on may keyboard...what is this?
    Guru:
  • 109 Answers
Its shows that The CAPS LOCK is ON.
Posted on May 10, 2010
How do you turn on *** q550 backlit keyboard
If the letters & numbers on your keyboard looks like transparent plastic, then you have a back lit keyboard, but if the letters & numbers looks like they are painted on the key caps, then you don't have back lit keyboard.
let's assume that you have a back lit keyboard: Hold the Function [Fn] key and tap the Spacebar once. That will enable/disable the back light.
You can easily tell if it's a backlit keyboard because the spacebar will have a keyboard icon on the left hand side. If it has the icon, then your keyboard has back lights on it & it should work.
If it doesn't, then it's a hardware issue that a technician needs to fix.
Aug 29, 2014 | ASUS Computers & Internet
Keyboard letters are numbers and numbers are letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
Compaq presario v6000 keyboard not working properly
seems that the number lock is on for that keyboard look for Numlock and see if it's lit up and if so, toggle that. those keys are the numbers 0 through 9 on that keyboard. that should do it.
May 17, 2012 | Compaq Computers & Internet
Hi my samgsung n150 keyboard has a problem when i type letter o it come 6 then i type letter l it become number 3 pls help me..tnx
If you look at the keys in question, you will notice that the U has a 4, I has a 5, O has 6, J has a 1, K has a 2 and L has a 3. These keys are part of the embedded numeric keypad that is turned on when NumLk is on. On the keyboard (usually at the top edge beside the Caps Lock indicator) is a NumLk indicator that looks like a little padlock with a number in its middle. It will be lit or a led directly under it will be lit when NumLk is on. To turn NumLk on or off (toggling) usually requires pressing and holding down the Fn key then momentarily pressing one of the function keys at the top edge of the keyboard which has the letters NumLk on it.
Apr 30, 2011 | Samsung N150 (36725723009) Netbook
Dell inspiron 1501 laptop keyboard is typing odd numbers and symbols instead of some of the lettters. Examples, the letter "l" comes out "3" . Other letters come out as a back slash, etc. A plug in USB...
Is the Num Lock light lit? This light is the one all the way to the left of several on the computer to the left of the power button (it looks like a padlock with a 9 in the center). The integrated number pad is probably active. Press to toggle this feature off. The Num Lk key is to the right of the various function keys but to the left of the keys labeled Insert and Delete.
I hope this helps.
Oct 16, 2010 | Dell 0Y3740 Keyboard
When typing regularly each letter gives a differ letter thats on the keypad.
First check to see if the LANG is lit on the display, if so Code "L: will turn it off. If that is OK then Press coce and "L: key, release the code, type 001, release the "L" key. This will set the keyboard to USA standard. If this works your keyboard is failing. Contact
George Beyers Co. @1-800-392-8085 for a keyboard rebuild.
DickyO
Jan 14, 2010 | IBM Wheelwriter 30 Typewriter
How can I tell if caps lock is on please? I have an Acer 5732Z
You can use the Keyboard Acessbility options to activate sounds for these keys (CAPS, NUM and SCROLL LOCK) for XP just follow these steps http://www.worldstart.com/tips/tips.php/102
Jan 13, 2010 | Acer NSK8458AN Keyboard
My keyboard shows a lightly lit light below f10
replace ur keyboard, its defect in the hardware!
Dec 30, 2009 | Toshiba Portege R100 Notebook
The keyboard doesnt work
Either replace the keyboard or try and get the latest driver download for your keyboard
Aug 05, 2009 | Dell OptiPlex 360 Desktop Computer
Jumbled numbers and text
Look for the numlock light somewhere near the keyboard. It's the light with a drawing of a lock with a 9.
If it's lit up. turn it off by pressing the numlock key.
Turning it back on will activate the number keypad (consists of 9-11 keys in the middle of the keyboard). So instead of getting letters, numbers appear.
Hope this is your case. Kindly rate me if the issue got fixed.
Oct 03, 2008 | Computers & Internet
Toshiba Satellite Pro 4600 Notebook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
