Question about Sony KDL-52XBR5 52 in. LCD HDTV
Video inputs composite or rgb cause no picture but
Just recentlyconnecting any device to composite or rgb video inputs cause no picture but flasing blue,pink,red screen HDMI and PC inputs work fine set is less then 3 yrs old
  • 178 Answers
> I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board
Posted on May 10, 2010
How to connect dvd player to LG RZ-32LZ55 in LCD TV
This 'TV' is really more of a video monitor. It has one DVI input, 2 SCARTS (1 RGB); component video input; composite video input; S-video, and stereo audio and RF inputs. Best picture would be using the component inputs if your DVD player has the outputs. If not you'll have to consider the S-video or composite (yellow) plugs. (Neither is HD capable....)
Jan 20, 2015 | LG Televison & Video
Why does my new 55 inch Polaroid LED TV display a
bad cable or cable not plugged in properly. Black and white will come out if you have a composite (yellow cable) plugged into a green on the RGB. If you are going composite then you need to plug into the yellow video input.
Sep 22, 2014 | Televison & Video
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
My video yellow plug works fine, showing correct video colors yet, the red blue green connection is only showing picture in a pale green
Yellow is composite input if RGB is not working it's probably a cable/output problem try with a different device first.
Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
No video from rgb inputs
usually this is a bad connection on the system board, cable, etc.  If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit.  Worst case scenario is replacing the system board where the connections reside.
Oct 19, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony KDL-52XBR5 52 in. LCD HDTV Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
