Question about Great States 415-16 16-Inch Standard Full Feature Push Reel Lawn Mower With
How do you adjust push-reel mower - Great States 415-16 16-Inch Standard Full Feature Push Reel Lawn Mower With
    Sniper:
  • 53 Answers
You don't! Usually. Some allow height adjustments only. Others do not! One height fits all! On a side note...I hope you are a youngster! Maaaan! those puppies really require more push energy than you'd think. And if you aren't a young'in I sincerely hope you got a "victory garden" patch or something small in area...WHEW! But...I have seen them for sale "new" as recently as 2 weeks ago. (I'd rather faint from trying to pull start my "self propelled" baby!
Posted on May 10, 2010
Testimonial: "Thank you! That's what I thought. I looked up Great States the maker of the lawnmower, all I found was the retailers who sell them. silly me I thought I could down load a owners manual.LOL"
  • Ed Gore May 10, 2010
    Oh How do you adjust a push mower? (it just hit me) Tilt forwards at 60 degree angle whilst pushing, if that don't work try 45 degrees!
    You probably could! Hey? it can still need repair, right? and the only thing I can tell you with that type of mower is "keep the blades sharp!" The sharper they stay, the easier the work is. Its directly related to the ease of use. Fortunately, those types of mowers cut by "sheering" very much like scissors sheer. Keep those edges square!
Tip
Brill Razorcut As functionally elegant as a bicycl
Brill Razorcut As functionally elegant as a bicycle, the Brill RazorCut 33 Reel Mower ranks as a highly efficient human-powered machine. It's lightweight and easy to push - with no need for gas, oil or electricity!
MANUFACTURER'S INFORMATION
• Contact-free cutting, precision ground flame hardened bearing mounted blades • Cutting height: 0.7 - 1.8 inches (14-45 mm) easily adjusted, indicators both sides • Large hood protects overhanging flowers and shrubs • Rigid ergonomic handle with foam grip • Mows a 13-inch swath (33 cm) • Cutting technology: Blade cylinder, 5 blades • Weight: 15.21 pounds (6.9 kg) • Wheel diameter: 8 inches • Recommended for areas up to 2150 sq. ft. • Made in Germany • Two year warranty
on May 08, 2009 | Brill Razorcut 38 Push Reel Lawn Mower
Height adjustment
Mowers I presume...?
As a child...
I remember the reel (push - manual) movers
had a combination of wheel and roller height
where adjusted.
As these many decades have shot by like a
time machine scene... mowers became 4 wheelers...
self propelled and even battery powered and
Self propelled...
See:
CONSUMER REPORTS recommendation below
May 11, 2017 | Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My reel mower pushes great for a few feet, then it seems to get stuck. I bought a returned item (unknown until I got home) and am not sure it is put together right. There were missing parts for the...
I think with those things you might be cutting grass that is to long, try to raise the height setting if possible and try cutting again. Do this until you get going then adjust back down to desired height. Good Luck...
Aug 28, 2011 | Garden
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | Garden
Scotts reel mower gear problem
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Great States 415-16 16-Inch Standard Full Feature Push Reel Lawn Mower With Logo
242 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Great States Garden Expert? Answer questions, earn points and help others
