Question about Dell Inspiron 6000 Notebook
Usb ports are not working
The laptop will not recognize anything plugged into them and the DVD drive will not recognize any disks in it. How do I get them to work again?
  • 3 more comments
  • sgt_roan May 11, 2010
    The device manager opens up, but nothing shows up in the view window. I can't see any device listed in the manager.
  • Abdulhakim
    Abdulhakim May 11, 2010
    Just wondering , when you click on device manager and see USB controller there does indicate a symbol ( an exclamation mark)?
  • Abdulhakim
    I can assure you it is not a hardware issue since you don't any device in the device manager.
    do you know how to fix the software problem? What is the software problem?
    CHANGE TO STATUS OF PROBLEM.
    I was mistaken in saying that the DVD drive does not work. The drive works just the USB ports do not.
    Guru:
  • 1,481 Answers
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
Posted on May 10, 2010
Usb not recognized and no removable disk drive
Try connecting the USB device to a different USB port on the same computer, or to a USB port on a different computer, to confirm that the USB device itself is working correctly.
May 07, 2010 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
The drive is not registered with my machine after I connect it.
u dont have any specific drivers that came with the Targus dvd?
..mabe the generic driver is not exepted!
..or ur usb port is not configured properly!
...do u have usb 2.0!
...did u tried on other ports!
...try to force usb 1.1!
...last step: in bios, try to putt usb dvd , or usb , (or anything similar), to boot from, (make sure u have a proper disk inside the dvd.)
if it worked (and its not simple, u need to make many tries) , then its driver problem, and in xp pro, every thing can be fixed ;)
gd luck
Dec 30, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore drivers...select usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Toshiba 160 GB Hard drive is not seen by 'new' computer
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
May 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
I have today puchased 2 x PNY 4GB USB2.0 Flash Drive but, nnot being very computer literate, I am at a loss to work out how I use them. I can't find a slot to plug it into. Do I need something else to...
These will plug directly into your USB port. Depending on the computer you have, the port location will change. On most modern desktops, there are two or more USB ports (http://www.shivaranjan.com/shivaupload/windowslivewriter/10WaystoNetworkTwoComputers_11F65/USBPort.jpg) in the front, and several more in the back. On most laptops, there may or may not be some on the back, but typically there are some on the side with the CD/DVD drive. Simply plug the device into one of those ports (make sure you put it in face-up), and your computer should instantly recognize it as a memory card/hard disk.
Aug 01, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Dell Inspiron 6000 Notebook Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
