I have a Magnovox tv/vcr combo that I am trying to use the antenna on but it will only let me switch back and forth between Aux or channel 3. I do not have the remote. Is that my problem? Will a universal remote have a button on it that will help with my problem? Thanks
Yes a universal control should solve your problem but I would try to connect my tv to my vcr or dvd and my antenna to my vcr or dvd as well then change your channels thru your vcr or dvd!
Posted on Mar 28, 2008
Sylvania tv/vcr/dvd keeps going from channel 3 to AUX
Hi my name is Mike Houston of DISH Network, with the TVswitching between channel 3 and AUX there are some things to check to resolvethe issue. You will want to make sure all connections are hand tight from thereceiver to the TV and to the wall. After all connections are hand tight checkto see if the channels are still going back and fourth. If it still persiststry changing the remote address, I will send a link that better explains thissetup; http://www.dishnetwork.com/SupportSection/remote-setup
Nov 26, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
