Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Craftsman 26HP Lawn Tractor Parking Brake
I have loaded my Craftsman 26HP 54 inch cut it onto a single axle tilting trailer at least 8 or 9 times put the parking brake on and lowered the trailer deck no problems at all. However the parking brake has now started to slip and will not hold the tractor on the sloped trailer deck. Is there an adjustment (or do you have any details) as there is nothing shown in the manual only reference to a service?
    Master:
  • Craftsman Master
  • 645 Answers
There is not an adjustment on the parking brake. The problem you are having may be caused by the drive belt stretching.
Posted on Jan 02, 2018
ImpalerCo
  • 13 Answers
SOURCE: replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
SOURCE: We have a brand new Craftsman 26 HP, 54
adjust the tension on the idler pully or refer to your manual
Posted on May 14, 2009
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
  • 202 Answers
SOURCE: New Craftsman Garden Tractor died while working
you might want to check the fuse, located ynder the hood somewhere. also chech that all saftey interlocks are intact and not unplugged.
Posted on Jul 13, 2009
woobie dog
  • 1273 Answers
SOURCE: the belt does not stay on
Although the belt may still look good, it is most likely stretched. The cure is to replace the belt.
Best regards, --W/D--
Posted on Aug 01, 2009
What is the gap gauge for craftsman pyt 9000 lawn tractor 26hp
If you are talking about the spark plug, I would need the model number of the engine.
Jun 15, 2014 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
./model 917 273321 26hp hydro
well you need a new transmission for it. start looking on google or ebay. nobody here sells lawn tractor transmissions.
Aug 29, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Mod# 917289450 54" deck
Next time as the engine begins to stall, loosen the fuel cap.
If the engine runs smoothly, clean the vent holes on the gas cap.
Gary
May 04, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman mower with 26hp kohler smokes while cutting.
it sound like you put to much oil in it.if not check vent valve
Jul 16, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Can't get front wheel back on lawn tractor Craftsman 52-inch
Make sure you are putting the wheel on the right way. The rim may be off-set. The longer part of the hub should be on the inside.
Jan 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
