Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
No gas into carb
Got gas in carb bowl drained gas new gas starts with dumping gas into carbthrout but no run
  • 198 Answers
Take off the float bowl and make sure the float valve is moving freely. if not, take the valve out, if it rusty, try cleaning it or replace it.
Posted on May 10, 2010
Have a Kohler Courage 18 hp in a Cub Cadet! SPEC PS-SV541-3212! Had bad gas! Dumped and put on a new fuel filter! gas! Did not run before without the choke pulled almost all the way! still same
Remove fuel line at carb. Remove filter, Drain out all old gas from tank. Let all of the fuel run into container if you see trash and water spray carb. Cleaner into tank until all trash and water are no longer seen. Blow out with compressed air if possible.Put all lines back. Remove bowl from carb. Check the bolt you removed from bowl should have a vertical and horizontal orifice through the bolt, make sure it is clean, remove all trash water etc. From bowl making sure the bowl gasket is in place and not pinched. Hopefully it will now start if not probably carb. Overhaul next.
Aug 26, 2017 | HP Garden
It won't run and dumps fuel.I've dipped thecarburetor and cleaned it well.the fuel just runs out the lower spring covered house that dumps out onto the ground
The problem is a bit of trash is preventing the float needle from closing fully to stop the flow of gas. Try this; drain the float bowl then close the drain and turn on the gas. Tap the float bowl solidly with the end of a screwdriver handle. The object is to free up the float / shake loose the trash. If doing that a couple of times does not fix the problem, Remove the float bowl and spray the interior of the carb using spray carb cleaner. Pay special attention to the float pin area. With the float bowl off you should be able to gently lift and lower the float. Lifting should shut off the gas and lowering should let the gas flow again. If the float shuts off the gas when raised, put the float bowl back in place and see if the carb still over fills. If so, then the float is defective and you will need a new one. Please rate my answer. Thanks. tombones49_151.gif
May 30, 2011 | Kymco 990 Super Duke Black Motorcycles
My bike was running fine yesterday and i went to start it today and it will try and start but wont run. what could be wrong?
A likely problem is water in the carb float bowls. Water condensation in the gas tank can get to the carbs and will collect in the float bowls. Drain the bowls if a drain bolt/screw is present or remove the bowls and dump out the water. Also, is the kill switch on? Is there gas in the tank? Do you have spark? Did the battery go dead? Bad fuse?
Aug 04, 2010 | 1979 Yamaha TX 750
Yamaha blaster runs but wont rev
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb.
Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
849880b.gif Please rate this solution. Thanks!
Jun 21, 2009 | 2003 Yamaha YZ 250
Won't crank, have drained the gas and replaced, added carb cleaner, replaced spark plug but will only run for 5-10 seconds at a time
ALWAYS have a fire extinguisher at hand when working on carburetors.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
May 05, 2009 | 2005 kawasaki KLX 125
Bike has being lieing up for 2 years and iv tried to get it started with some damp start and choke but it only seams to run for a very short period. when you open the throtle it just dies its doing my head...
Drain the carburetors. There should be a screw on the lower side of each CARB float bowl. Remove the screw then replace it after the fuel drains. Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, (not all bikes have a water trap bowl). Remove the tank and dump the old gas. Refill and use premium gas. Turn the gas back on and wait a minute for the carbs to fill with gas. Install new stock NGK spark plugs and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetors from the engine.
FOR EACH CARB > Remove the float bowl and clean the entire
CARB with a spray CARB cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the CARB. Remove the idle screw and the air screw on the outside throat of the CARB and spray into the screw holes as well.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
CARB back together, clean the air filter and install the CARB. Let the float bowl fill then start the engine. INSTALL AN IN-LINE FUEL FILTER.
If the inside of the tank is rusty then get a liquid liner.
Google “ kreem fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
Apr 17, 2009 | 1998 Honda Hornet 250
Sunk 06 crf 250x in about 3ft of water?
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). INSTALL AN IN-LINE FUEL FILTER. Remove the exhaust and dump the water out. Lube the chain and cables.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
carb back together, If a foam air filter, then clean and dry it. If a paper air filter then replace it. Install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. Hope the CDI was not damaged by the water.
Apr 11, 2009 | 2005 Honda CRF 250 X
Tink carb trouble
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. GENTLY screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Mar 29, 2009 | 2005 Yamaha Ybr 125
IDLE
Drain the carburetors. There should be a screw on the lower side of each carb float bowl. Remove the screw then replace it after the fuel drains. Any water in the gas? Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well. Don't be chincy with the carb cleaner. Use a lot. Until the idle curcuit gets un-varnished the problem will be there.
Mar 29, 2009 | 2004 Honda CMX 250 Rebel
1995 fzr600 bogs out a little when taking off
Drain the carburetors. There should be a screw on the lower side of each carb float bowl. Remove the screw then replace it after the fuel drains. Any water in the gas? Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Turn the gas back on and wait a minute for the carbs to fill with gas. Install a new stock NGK spark plugs and try to start the engine. If the bike doesn't start and run properly get back to me.
Mar 29, 2009 | 1995 Yamaha FZR 600
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
104 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
