Question about GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH
Bought a new gasket - any hints to make installation easier?
See above; any help would be appreciated.
    President:
  • 949 Answers
The title of your question is cut off so I am guessing you are wanting tips on how to make the job easier.
First hold up the new one to make sure it is the right gasket. (there is nothing worse than taking it apart and finding the part is wrong.
The best way to replace a gasket is to soak the new one in warm water prior to the installation. This will soften it up and make it more flexible and forming.
Remove only part of the old gasket before putting the new one on, for example take the screws out from the top row and a few down each side of the freezer liner that holds the old gasket on. Carefully peel the old gasket off leaving it hang.
Start the new gasket in the center of the top and work your way to the corners. Work your way down to the bottom, tightening along the way.
I hope this helps
Posted on May 10, 2010
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Help with Light for Fridge RS265TD RS
Most refrigerators have a switch somewhere. look for a little white triangle either at the top or bottom. there may be a push button style somewhere along the upper hinge cover.
Nov 05, 2013 | Samsung RS265TD 26 cu. ft. Side by Side...
MY REFERIGERATOR TURNS ON BUT DOESN'T COOL
if it is a fros free check fan in the frezzer that is what cools the frige
Sep 12, 2012 | Danby DFF9102W Mid-Size Refrigerator White
Fridge keeps on running and getting colder and colder
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 20, 2011 | Silver King 1242.90 Front Breathing...
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Apr 06, 2010 | Freezers
Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Apr 11, 2009 | Freezers
GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH Logo
85 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
