Question about JVC AV-32330 32" TV
Black Box in the center of the picture
For some reason theres a black box about 1/3 the size of the picture in the middle of the screen. It goes away anytime you push any button, but comes back within 3 seconds. I've tried everything i can think of. Please Help.
It's the text screen
remove by using the top left hand
side button on remote.
help me aftervpower off by cable co installer
now have NO sound
but have the sound register graph rising 0 - 50
Posted on Apr 02, 2008
SOURCE:
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
go into the menu and turn your closed captions off or if there is a cc button on your remote you can turn it off that way.
Sep 08, 2009 | Hitachi 57F500 57" Rear Projection...
There is a rectangular black box across the screen - it goes away when I use the favorite button and have multi screens showing - it returns when I close out the favorites. Color, sound, picture quality...
in the customer menu--find the closed caption settings---you will most likely find the set has been set to TEXT 1---with the remote select either CC1 or OFF---the black box was for text (books) and was not ever used much---usually someone engages it by accident
Aug 07, 2009 | Toshiba 57H81 57" Rear Projection...
Get a black square box in the middle of the screen
Turn off your Closed Caption, it's in text mode.
May 30, 2009 | Insignia 37" LCD Flat-Panel HDTV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black box
Good Day,
With black box, get the TV's remote and turn OFF the "closed caption". You are in the text of your cc. Good Luck, big IRISH.
Jun 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
JVC AV-32330 32" TV Logo
82 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
