Question about Daewoo DWC063R Air Conditioner
Have a DWC-058RL. Does front plastic come off for cleaning?
Have a DWC-058RL. Can't find the manual. Need to know if the front plastic grill comes off for cleaning?
How to Remove the grill on my deawoo Dwc-055rl air conditioner
at the lower outer edges of the grill you will find indents
place your fingers at these points and pull out and up
the grill will lock up while you attend to the filters
closing is just pressing down on the grill until is clicks into lace
Jul 18, 2016 | Heating & Cooling
Just want to remove front panel to clean
Anna, Normally front is not fastened with screws. In case, first check for any screws that could be holding cover in place and remove them. To remove front cover normally you push down on the top plastic frame which helps release clips, while pulling or pry cover off towards you, in the same area.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clean Window Air Conditioner
LG LWHD1200R Owner Manual How To Remove The Front Grille
https://answers.yahoo.com/question/index?qid=20090815115103AAsYyOK
http://www.geeksonhome.com/how_6562969_clean-kenmore-window-unit-ac.html
Jun 19, 2016 | Heating & Cooling
How do you remove the front plastic front piece to clean the "grille" behind the filter?
Has to come off somehow. Maybe there are clips holding it in place. Was put together by man so it can be taken apart.
Sep 20, 2015 | Heating & Cooling
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic...
I have the exact problem with my LG LHD45EL as lubbock51's Aug 17, 2010 question. (see below) Isn't there anyone out there that's had this same problem and resolved it. I too am afraid to pry the grill for fear of breaking it...it made out of plastic so it won't take much to break the grill if I did.
By lubbock51 on Aug 17, 2010
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic in fear of breaking it. Any suggestions?
Aug 17, 2010 | LG LHD45EL Dehumidifier
I see mold growing inside the cabinet where the air blows out. Can I take the front grill off without breaking it?
Hi, carefully remove the control knobs first. Then behind the knob you should have screws.to remove, Some units the front just un snaps and comes off, but do be careful as you can crack it. The mold is coming from the coil behind it. You will need to give it a good cleaning. They make a coil cleaner, but you can use 409, of a mildew cleaner. Best of luck,
Shastalaker7
Jun 14, 2010 | Daewoo DWC-056CL Air Conditioner
I need an operating manual for the electric grill.
The manual is located on a tab at the bottom. http://www.charbroil.com/Consumer/product_detail_m.aspx?ProductSeriesID=24
Jun 07, 2009 | Char-Broil Patio Caddie Grill
Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Daewoo DWC063R Air Conditioner Logo
285 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
