Question about Cycling
SCHWINN AIR DRIVER 1100:HOW DO I USE IT TO PUMP AIR INTO BEACH CRUISER TIRES
SCHWINN AIR DRIVER 1100How do you assemble the air pump for bike tire
Posted on May 18, 2010
Troubleshooting guide
Are tires fully inflated? Is there any thing in the chain or around the chain? Suggest taking it to local bike shop
Apr 23, 2014 | Schwinn Windwood 26 Women s Cruiser...
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar.
They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.10_19_2012_7_26_19_pm.jpg
Oct 19, 2012 | Schwinn High Timber Girls' Mountain Bike...
I have a schwinn steel floor bicycle pump with a guage Do I need to periodically oil it so it wont lose pressure while pumping up tires or a ball?
Hi sixgnsannie1
I will answer yes on the use of oil to act as a sealant so the bike pump will not loose pressure while filling your tires or balls.
Just a small amount will do it, do not over oil.
Please take time to rate me
Sep 08, 2011 | Pacific International Schwinn Bicycle...
My old Schwinn 26" red
Web search "fix shimano internal gear hub" or whatever the bike has.
Aug 09, 2011 | Cyclone Bicycle Pedal Crankset And Arms...
How do i change the chin???? thanks, mike
You need a special tool to push out one of the pins in the chain. Park tools has several, and they have how-to videos on their site. http://www.parktool.com/category/chain Good luck, Al K
Jun 14, 2011 | Schwinn 2010 Debutant Beach Cruiser Bike
I just tried filling up the tires on my schwinn cf 1000 but all they air drained out and the air pump isn't working correctly. how do i get air in the tires!!!! THANKS
This sounds like what happened to me with my bike a couple weeks ago. Sometimes the tube gets shifted inside the tire and keeps air from flowing in. I had to take my bike to the shop so they could shift it back into place and also replace the air valve. If you have the right tools and expertise this can be done at home, but since I have neither I could not. :)
Jun 07, 2011 | Cycling
Micargi men's cruiser - do I need metric or english tools?
since its made in china, My guess would be metric,, But remember that a 13 and 1/2 inch are the same , so is a 15 and a 9/16 I have a Schwinn that actually needs both ,, the main thing is to make sure its a tight fit so you don't round off any nuts or bolts , by the way the english tools are called SAE , if you need heres a conversion chart http://www.vaughns-1-pagers.com/science/wrench-conversion.htm Please take a moment to rate my reply and research Thanks Good Luck
May 08, 2011 | Comfort LLC Micargi Touch 26" Women's...
Schwinnn men's 26 " jaguar
The tires will say on the side-wall, it's likely around 45-50psi.
May 05, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
How does one get the needle to work
Hi
That pump was making me nuts tonight so I had to pull it apart to see how it works. It looks like the air should come out of the needle when the lever in the rear is resting down. The squishy rubber tip up front should push the internal valve to the rear and the needle hole lines up. My issue is that the assbly was jammed up and it would not let me put the thing on a tube valve. So if you can't put the pump on a tire then the internals are stuck forward in the "air out the front" area. Try to give the hole a nice push to the rear and see if the needle kicks in. It works like a faucet sort of.
Pull off the front valve and see if the internal piston moves front and rear while you push it back and the lever will push it forward. I think they are of low quality based on the few I have seen.
Dec 18, 2009 | Schwinn Cycling
Cycling Logo
810 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
